What is cooler, topless or a running singlet?
I’ve been poking around the Internet on the issue and all I find is runners and HS coaches yelling at each other, each sure that they have the right answer. And not a one of them with 10min experience in the physics of heat transfer.
For me it’s mostly that within a mile or two any shirt I’m wearing is soaked, clingy and icky.
IMO, if you had a tight-fitting white shirt made from a fabric with a high surface area and high thermal conductivity that would be optimum. As far as I know, that last point of criteria doesn’t currently exist.
As with everything this topic is about balance. In different conditions, recommendations can change wildly.
It would be very difficult to truly spell out everything here, but I will cover a few topics.
If anyone wants additional details, contact me at RPickels at Pearlizumi periodthing com.
I get to think about this stuff every day!
There’s peer-reviewed research to back all this up.
Fabric Color:
White is cooler because it reflects the sun, right?! While yes, what doesn’t get reflected makes it through the white fabric and to the skin. In some research this increases skin temperature and subsequently sweat rate. With black fabric the fabric surface temperature is increased due to radiant absorption, but less makes it to the skin and skin temps / sweat rates are lower. There’s research that goes both ways on this. 6 of one, 1/2 dozen of another. Individual parameters of fabrics can push in one direction vs. another.
Sweating:
Whomever mentioned “Latent Heat of Evaporation” is entirely correct. The energy needed to change water from liquid to gas phase takes tremendous energy 2,000+ kj/kg. Remember that a joule is a watt / second. Sweat 1 liter per hour and you can remove 2,000kj of heat. At 200 cycling watts, you’re producing approximately 600 joules of heat per second. That’s 2,160kj per hour… which is basically the heat 1 liter of sweat evaporated completely and directly from the skin can remove.
Notice what I did there? Completely and directly are the most operative words in sweating. If that sweat drips from your body, it does you no good. If the sweat evaporates off your clothing instead of your skin… it does you significantly less good. This is why base layers in hot weather are silly. It’s a crazy crazy world.
Drinking vs. Pouring over your head.
Are you soaked in sweat? Drink the water. Are you fairly dry and sweaty in a couple places? Pour it over the dry areas. Evaporating it removes much more heat than raising it from 1c to core temperature. Drinking a slushy will buy you more heat loss because of the additional energy needed to convert solid water to liquid, but still less than later heat of evaporation.
Shirt vs. No shirt:
Certain fabrics can spread moisture. There’s a lot of ways to do this. Is it helpful? Maybe. If sweat is pooling in a particular area, it’s not helping your cool because it’s not evaporating. Spreading that sweat over a larger area will increase the evaporation rate. (Think about a glass of water vs. spreading the water all over the table… it’ll dry quicker over the table). If you’re so sweaty that you’re wet over most of your surface area, the wicking shirt isn’t doing much additional work to cool you.
Surface area & conductance:
Yes this will help cooling of the fabric, I’d say the conductivity would have to extreme to rival partial evaporation directly from the skin because you lose so much by evaporating away from the skin. I’ll put this into the pile of math that I need to get done at work.
More later, if I get a chance.
Over the past week I’ve been back wondering about this same issue. So I went poking around Google and, to my very great surprise, I stumbled upon this thread, started by one of my earliest posts here at Slowtwitch. But even this thread never really resulted in the kind of science based hard answers I was looking for. Altho some folks in the thread pointed out that people in desert environments wear loose fitting clothes, there is near consensus from those that train and race in the heat that shirtless is cooler. My guess is that the more clothes in the desert anecdote doesn’t account for the fact that the racer is creating most of his heat and needs to dump it. Whereas the dude in the desert isn’t so much creating heat as trying to shield himself from radiant heat.
Humidity is a big issue too. I could imagine that when humidity is pretty high, a shirt could help evaporative heat losses because of the high surface area of high tech shirts. Certainly with no shirt you don’t get much evaporative heat loss because in high humidity your sweat just drips off. But convection is a big deal and a shirt is certainly going to reduce convective heat losses.
What we need is some studies that look at optimum solutions for different temps, sunlight intensity, and humidity.
Quick note on this one.
From high 90’s F to 100+ degrees and you’re rivaling to superseding skin temperatures while exercising (depending). Therefore you begin going from Convective loss to the environment to neutral to convective heat gain from the environment, which is the benefit of wearing multiple loose layers. It’s basically insulation against gaining Convective heat.
Solar radiation is very dependent on Air mass which is affected by Elevation angle and altitude.
In the summer, there isn’t too much difference in elevation angle based on location on the earth. Going from Sea level to 5,000 feet results in a larger gain in radiation than from London To Cairo. Both however are insignificant compared to the changing of seasons which can easily reduce solar radiation by 25 to 50% depending on location. However, season makes a large difference as it results in a large Solar Elevation angle difference.
Long story short, during summer Egypt has less solar radiation than Denver. ~1050w/m2 vs. 1030w/m2 vs. 1000w/m2 for London. Egypt winter is ~850 w/m2
