What does this mean? (1)
I just got sent an abstract that is looking at single leg pedaling. In order to make single legged pedaling seem “natural” to the participants they had to add 20 lbs to the unused pedal. Does anyone have any ideas as to what this says about normal pedaling dynamics?
Is this a trick question? It says that in normal pedaling dynamics there is a weight on the downstroke that counters the force required on the upstroke.
Sounds like they may be trying to determine if single leg pedaling induces training effects on the non-pedaling leg.
Not a trick question. I had always assumed that the leg weighs about 20 lbs but that we typically unweight 15-18 of that when we normally ride. Therefore, I would expect that perhaps we would only have to add 2-5 lbs to make single legged pedaling feel normal. That is not what they found. Why did they have to add essentially the entire weight of the leg? From a PowerCranks perspective have I been making wrong assumptions about how much extra work we are asking the HF’s to do?
I’m guessing that ‘joe public’, relatively untrained and unskilled in the finer points of pedalling dynamics would be less likely to unweight the upwards moving leg. Perhaps that’s the assumption made.
Who were the participants?
I will have to find the study write up. Seems to have disappeared from my computer. As I remember, they were experienced cyclists but can’t be sure. I will try to get back with that info.
My guess is that they were more than likely trying to emulate the downstroke of the missing leg rather than the upstroke. The result would be that the test subject would require less exertion on their upstroke and the the additional force needed for the downstroke would be less noticeable. (Since the bulk of the work occurs on the downstroke)
I wouldn’t try to read anything into the actual 20 lb value being some scientifically calculated value for nominal ‘negitave’ force on the upstroke.
Single-leg pedaling feels un-natural on the upstroke. The weight on the opposite of the pedal helps that particular part of the stroke, making it feel more normal.
I doubt that the 20 pounds is that noticeable as additional resistance on the downstroke, and if it is, it isn’t to the extent it is on the upstroke.
All the weight is doing is aiding the hard part of the stroke and making the easier part of the stroke harder, effectively mimicking an ‘even’, 2 footed pedal stroke. I don’t think there’s anything worthwhile to gain from it.
That is exactly what they were doing. The question goes to “why is 20 lbs the correct weight to add?”
20 pounds is around the average down force for an untrained cyclist.
I’ve ridden that device in the lab that’s doing the testing, and spent a fair amount of time talking to researcher who is leading it. My business partner is also a professor at that university and has been pretty involved in the research, so I’ve learned a fair amount about it. It’s very interesting, but I’m not sure how much info they want divulged just yet.
As to who has used it, or rather the level of cyclists who have been on it, in light of not being sure of how much they want known yet, I won’t name names, but there have been podium finishers from the Tour, classics winners, etc, so pretty high level guys, all of whom thought it was beneficial.
What’s by far the interesting thing here isn’t the pedaling dynamics, or what this says about how people pedal, though. Rather, it’s the physiological responses they’re able to generate with this device and the subsequent training effects.
Really a pretty fascinating study based on the premise that people are highly inefficient at the cellular level and the subsequent aerobic performances (or lack thereof) compared to other species.
I would be interested in hearing why they think this says something about what is going on at the cellular level as opposed to other species, especially as regards cycling as no other species cycles as far as I know. I look forward to seeing or hearing about the paper when it is available.
Here is my layman’s explanation, since I am not a physiologist. Looking at a couple of physiological traits, such as mitochondrial density and VO2 max, humans are pretty low on the totem pole, as was explained to me by Jim Martin, the professor whose lab this is in. For example, if we look at the prong horned antelope, they have a VO2 max of about 300 and can run 11K in 10 minutes.
All of the various types of training we can do to improve performance, in terms of overload and recovery, are from a physiologists perspective pretty similar and limited as to how significant physiological changes to the subject will be. If we can find a way to significantly alter the sustained workload, perhaps we can affect change at the cellular level such as increasing mitochondrial density.
Coming up with a way to significantly overload a system requires training that isn’t currently being done, and single leg cycling (as differentiated from single leg pedaling) allows for such an overload because you can isolate a muscle group and push it to more than it’s normal sustainable workload without being limited by the aerobic system.
So, again, take my interpretation of what they’re looking at with a grain of salt as you’re getting my interpretation of an explanation that was given to me when I was in the lab there 4 or 5 months ago.
Thanks for the thoughts. I would agree that mitochondrial density would be a strong predictor of sustained workload. Other major predictors of this, I would predict, would be the amount of muscle mass involved and the relative mechanical efficiency of the effort.
But, I don’t see how single leg cycling causes such an overload per se as it is described in the abstract. Where is the overload coming from? However, I can see how single leg pedaling causes an overload in the HF/hamstrings. So, it seems the thoughts as regards the “overload” are backwards.
Martin comes from the “just push harder” camp of cycling so he would probably disagree with my assertion that technique or efficiency plays a role in sustained workload ability.
Anyhow, I look forward to the paper. It most certainly sounds like it may evoke a lot of discussion.
If you can send me the abstract I’ll do my best to correlate what I know with what they’re trying to achieve.
Having ridden the device they’re using I can tell you that it definitely overloads the leg that’s pedaling to a degree that can’t be accomplished with 2 legged cycling.
I have sent it along to the email in your profile. I would post it here but I don’t want to compromise any ability to actually get the study published. I see nothing in the abstract talking about overload.
