Does anyone know what defines a “climb” in a bike race? Ascent height, distance, grade, etc…? What differentiates a cat 1 climb from a cat 2 etc…? Is it a race-by-race thing?
From http://www.cyclingnews.com/road/2004/tour04/?id=features/FAQ
What do the climb categories mean?
Climbs are graded according to their severity, from fourth to first category, plus the very hardest climbs which are considered ‘hors categorie’ or ‘beyond category’. The gradings take into account the length and steepness of the climb and the position of the climb in the stage, with the quality of the road surface making up a final, less important factor.
How are the gradients calculated?
A grade of, say, ten percent, simply means that the road ascends ten metres for every 100m it travels horizontally. For those with a mathematical bent, it’s a simple tangent ratio. Climb grades are averages for the whole climb, so a straightforward-sounding six percent grade can hide some much steeper pitches that make it a monster.
I know that climbs are categorised Cat 1, 2, 3, etc., but is a “1” more difficult than a “4”, or is it the reverse?
The categorisation of climbs is determined by the race organisers, and is based on the steepness of the climb, the position of the climb on the stage, and to a lesser extent, the quality of the road surface. Generally speaking, a climb needs to have an average gradient of around 4-5% and a vertical elevation of at least 100 metres for a climb to be categorised. A hors categorie (literally meaning ‘out of category’) climb is the most difficult, with an elevation usually 1,500 metres (5,000 feet) or more above sea level - while a category 3 climb is one of the easiest, with an elevation usually in the range of 300-600 metres (1,000-2,000 feet) above sea level.
It depends…do you live in west Florida or in colorado?
The climbs in southwest Florida are far more pathetic than west florida in the panhandle. The only times that the road is not pancake flat is when there is a bridge over a waterway. They are truly pathetic. Last weekend I showed a triathlon friend visiting from out of town and said these are the biggest “hills” in town and laughed. The reply back was that they are barely speedbumps.
