What chain to use?
With a new Dura Ace 10 speed set up…
The Dura-Ace chain is pretty good if you ask me.
I hope to God that you do not have a complete D10 group on your bike if you are wondering which CHAIN to use. SRAM may have something cool by now.
Naaaa just the drive line…have not bought a chain yet…
wipperman - no question about it.
Wipperman with Connex link. This beauty is VERY strong and has the connex link which can be opened by hand without tools, and is very easy to remove for travelling and cleaning.
I just got a bike with DA 10 speed and my chain whip doesn’t seem to want to work. Is it me? Any tricks to make it work or do I need a new one for the new rig?
Chain whips are sold specific to whether it is 9 or 10 speed or if Campag or the other one ;-). I changed whips when I went 10 speed in 2000, so can’t nip out to the garage to check if they are interchangable, sorry. I always take a couple of goes to get the whip on in the right direction, cos I’m just slow I guess. Not sure if it just marketing but I would suggest you require a 10 speed whip, your new group should deserve this anyway!
Chains, whips, and handcuffs all leave pretty bad marks on the wrists so I prefer ropes…
oh, wait. Wrong thread.
Would you be Ben “dover” Davis?
:wink:
  1. I like the Wipperman chain, mostly because of the connex link. I think it likely works a little better on Campy than D/A because it’s a little wider than the D/A chain, but thinner than the Campy (I run Campy). The D/A chain sucks because it has a relatively short life (supposedly) and uses one-time use pins.
  2. My chain whip, a very generic one, works on my ten speed stuff. I’m sure it’s not 10 speed specific. Yours should work fine if it’s a 9sp version.
i have a personal bias, and it’s system-specific, not brand-specific. every now and then you find a paradigm that either campy or shimano just rebels against. sort of a stubbornness thing.
campy appears to be steadfastly against spline cranks/bbs. i give campy 3 more years to even BE in the crank biz if they don’t change that tune.
shimano was dead set against threadless headsets and now they ARE out of that business, or are in any meaningful way.
both companies are against connex link type systems (that’s the wippermann system) and SRAM has a similar system.
both shimano and campy are just flat out wrong, in my opinion, for several reasons. the connex-style master link systems:
  1. almost eliminate user error when mounting chain
  2. you can remove chain for cleaning
  3. you can remove chain for bike travel
  4. you can shorten chain, if need be, without the necessity of another master link.
8sp? the old way of doing business was fine. 9sp? hmm. chain’s pretty narrow, contact area between pin and plate very small, very precise. 10sp? fuggetaboutit. in my view.
personally, i’m predisposed to wippermann, for several reasons:
  1. they are my client
  2. the chains are made in germany
  3. the company is generations old
  4. all they make are chains, all the way from huge chains that raise and lower elevators down in size to bike chains, and smaller yet.
  5. i have a lot of history riding these chains without a failure or hiccup.
however, i’ve also ridden SRAM chains, and they worked flawlessly for me.
“campy appears to be steadfastly against spline cranks/bbs. i give campy 3 more years to even BE in the crank biz if they don’t change that tune.”
Wow, why? I never really thought it mattered one way or the other. I’ve never had an issue w/ my Campy tapered squares. Campy could go to ROUND and I’d still pick 'em over Shimano. :slight_smile:
I have never had a problem with Campag cranks or bottom brackets. The only time I have had a problem in that area is the one time I deviated from Campag and I think that has been well documented enough!
