This part came with my Dura Ace STI shifters. It was in a separate bag containing the DR cables and the little Hi/Lo gear indicator that mounts up near the right shifter. It is smooth on the other side. My only thought has been that one might use it to router out the ends of the outer cables (it is the diameter of the wire cables. after you cut them, which causes them to collapse a bit.
Wow…never seen that before, then again I avoid all things Shimano. Maybe you can cut it up and use it as cable ends so they dont fray? Maybe it is shop slag that ended up in your packaging…
I am the return spring installation tool.
This is for those who dare to remove the lever from the bracket/body.
GB
Grab–No matter what people say about you, you get points for this one! AND, you answered the questin appropriately by begining with “I AM…” AND you gave an explanation of its use, with some editorialization!
An all-around fine, fine response.
Chip, take note. This hurt you badly.
Monk - I was having a good day until I read that. What have you been saying about me?!?!
Throw it away and you will need to remove your STI lever for some reason the day following garbage day.
GB
Monk, I’d guess you were a either a crank, a dropout, or lawyers lips.
