hed trispoke, renn disk will be a bit under $800 if you get the trispoke on closeout at hed. the 404’s aren’t nearly as aero as this combo and much more expensive and the ksyrium’s aren’t even in the same ballpark.
Yep, used it is. I train on Ksyrium SLs - they are not aero at all (despite the cool bladed spokes).
I’d go for some 404s as well. A pair of 404s are almost a full pound lighter than a pair Hed3s and you mentioned that you mostly do hilly races. Actually, My 404s are lighter than my Ksyrium SLs!
I’m confused…you say “aero” and then mention “hilly” races. A bit of a conflict, but I’d recommend a 2002-2004 used Zipp 303 Tubular set-up…around $650/750ish on ebay.
If going new, you can get a dealer to sell you Hed Alps for around $800.
Or try Renn disk w/ the Hed Stinger 50 ($378 @ analyticcycling.com). Maybe not quite as aero in crosswinds as the H3… but significantly easier to handle in those crosswinds than the H3, quite a bit lighter as well.
FYI, according to wind tunnel data from Zipp the Ksyriums have about 1/2 as much aero advantage as a 404 compared to a 32 spoke training wheel, depending on yaw angle, see the chart on page 5: http://www.zipp.com/tech/documents/Anoteonspokecount_000.pdf
I’m confused…I thought a disc wheel was the worst thing to have in a crosswind. You’re saying the H3 is worse? Or am I misunderstanding because it’s my sleepy time of the afternoon?
The front wheel affects handling much more than a rear in sidewinds. Some people don’t have trouble with the handling of the H3 in sidewinds, but personally I didn’t care for it. Actually the problem is not so much sidewinds as it is gusty sidewinds. A disk should not be a problem in a steady sidewind but will definitely be more of an issue in gusty sidewinds.
