Wetsuit same effect as pull buoy?
I’m about to get my first wetsuit, and I keep reading how wearing one helps with buoyancy and body position. Is the effect similar to using a pull buoy? Should I be using the pull buoy in practice to simulate a wetsuit?
Is the effect similar to using a pull buoy? YES flotation and body position wise, except the wetsuit lets you kick but will restrict your shoulders a little (not very noticeable if fitted and put on properly…lots of Tom D articles on this on the bikesportmichigan website)
Should I be using the pull buoy in practice to simulate a wetsuit? NO, use a pull buoy if you want to isolate your shoulders but beware overstessing them…you’re better off working on your stroke including your rotation which pull buoys don’t really help with much. The better the swimmer you can be without the wetsuit, the faster you’ll be with it. If you want to practice wearing a wetsuit, find some open water and practice in the wetsuit.
