Wetsuit = lifejacket?
question: just HOW buoyant are wetsuits? If a swimmer passed out in the middle of a lake would they sink or stay at the top? Anyone know?
They should float, not to say you can not drown, but you probably would not sink anytime soon!!
I would definitely float in mine.
jaretj
thanks for the reply - I’m looking for an answer to give to the head of the local Search & Rescue team, is there anything more definitive?
I guess the idea depends on the thickness of the rubber, with a 5mm thick wetsuit bottom that is able to float a certain mass depending also on what type of rubber you are using. This would also be a great question for someone like Emilio DeSoto. Give him a call at the office.
A wetsuit should typically float you, but a guy drowned in his wetsuit a few days before IM Germany a couple years ago and appeared / popped up a few months later.
And that guy from Hungary was a low 50 minute IM distance swimmer.
Herbert
A swimmer wearing a 5mm wetsuit would most likely float, however a wetsuit is NOT designed to keep one’s head out of the water. So although floating, face down still equals a dead swimmer.
“So although floating, face down still equals a dead swimmer.”
Khai,
Great point. A wetsuit should never be considered as a lifejacket. Indeed, if for some reason you pass out or are knocked out, and no one was there to get you out of the water, in a wetsuit you would drown/die. If you had on a PFD, you would be flipped over on your back and your mouth and nose would be kept out of the water.
I think that a wetsuit adds some degree of safty for open water swimming, in that should you run into problems, and remain concious, it will take less energy to tred water and stay afloat than if you had no wetsuit on. The wetsuit would also keep you warmer, than if you had no wetsuit on.
I’m thinking that the guy who died at IMFL was probably wearing a wetsuit. I think in most swimming-related circumstances that would cause you to drown (blackout, heart attack, severe head trauma, prolonged submersion, tsunami, shark attack…) a wetsuit is not going to help.
If you are having the same argument with the SAR that I had all I can say is good luck.
Me and a few of my tri friends tried to get the local park service to allow open water swimming outside the 40 meter long roped off designated swim area because as you know, swimming in a smallish area doesn’t allow for optimal sighting practice or the feel of open water distance.
Our point was, yes you could drown but at least body recovery wouldn’t be an issue (which honestly is all they care about) in terms of cost. They ended up saying they didn’t want novice swimmers to be tempted to try the open lake by a bunch of triathletes, that they didn’t have the personnel to enforce a wetsuit requirement, and that they wouldn’t be able to tell if we were in trouble because they had to focus their attention on the designated swim area.
We were left with either violating the regs and getting a ticket (I talked my way out of two violations) or swimming in SF Bay (much safer, NOT).
Good luck and let me know how you do.
