Wetsuit newby here,
Just bought a wetsuit for a race and need to practice with it. The closest lake for open water swimming just isn’t convenient. Is it detrimental to my wetsuit to swim with it in a saline pool? The “care instructions” indicate that chlorine is bad for it. Any thoughts?
Pool chlorine and Saline are two different things so I wouldn’t worry about it. I would still give it a good rinse afterwards. If a tri wetsuit manufacturer made a wetsuit that couldn’t handle salt water they would be the dumbest f^*%ing company ever
saline pool shouldn’t hurt it but best bet would be to call the manufacturer, that being said, even though it is not convenient for me either i always test a new suit out in open water as i fear that i would end up getting posted about in the strange denizens of the pool thread…
Two thoughts:
Soak the wetsuit in tap water for about 20 min. to make the neoprene more plyable before donning. This will also reduce the amount of pool water absorbed.
Saline/salt water pools ionize NaCl to make Chlorine. Ensure that the amount of Cl is ok for the wetsuit.
A couple of swims in the pool to test the fit and try it out are fine, but regular swims are usually not.
