It does looks like most of your weight is muscle, though I bet you could trim down 5-10 pounds of extra fat and feel a little more fleet of foot.
Your build is not that of a fast long distance runner, if you wanted to do that you would have to lose some of your upper body muscle mass. Whats cool about getting down into the 5-10% body fat range is you can lose a lot of muscle and still look ripped as the your muscle structure is far more visible.
As a comparison check out my blog www.smallsphere.com at 1" shorter I weigh in at 152 pounds. But then I just train for endurance races and limit muscle build up that isn’t’ specific to triathlon.
Thanks for the input. This past spring I stopped lifitng weights all together and anything I do in the off season will revolve around tons of reps and nothing too heavy.
I know that with my build I am playing in a weird area with distance running. Whereas a lot of runners are fast and go crazy, I am more like a big diesel and jsut keep pounding out consistent splits at pace. I am trying to BQ (3:15) at Chicago and besides my recent results, have a 19 miler at 7:20 pace on the hilly Balimore course.
But there’s no way to determine whether the improvement was from training or from weight loss.
I think you could get some indication since it is trivial to measure power during cycling these days and it is possible to calculate running power if you have a treadmill with elevation. If you lose weight and power stays the same, it’s probably not a bad assumption that any gains in pace are due to the weight loss and not the effects of training. Of course it would be difficult if not impossible if you got more fit and lost weight simultaneously to attribute any gain in speed to one vs. the other.
I had read that the % of body fat you lose will be equal to the % of time you gain. So if you are running 6 min miles and lose 2% body fat you will be running 5:53/ mile after losing 2% of body fat. It has to be dead weight not muscle. And that seems to make since. The faster you are the less the weight is going to affect you, as 2% of 5min/mile(6 sec. saved) is a lot smaller than 2% of 8min/mile(10 sec. saved).
From my experience I can agree. Last year I was 117lbs and 15%bf. Now I am around 105lbs not sure of my body fat, but I am leaner. I did lose some muscle weight, but also some fat weight too.
Last year, my fastest 10k off the bike in an Olympic distance race was 40:41. This year it was 39:48 on the same course but it was a much faster bike split by several minutes so I was more fatigued going into the run. But there is no way that with weight loss alone I could take off the several minutes that the original formulas predicted.
In my opinion, focus more on the training if you are already pretty lean and in shape. If you have a lot of weight to lose and are just starting out, the weight loss should help a lot more. Just losing weight isn’t what you are shooting for–you want to lose dead weight like excess body fat and the excess muscle if you are a really really muscular person.
