Website and server tech questions
a few questions about website hosting: i know you can pay someone to host a web site for you. but is it also easy or possible to host a site inside your home with a regular domain name (i.e., something like www ‘blankety-blank’ dot com) without breaking the bank? and if no one has previously used or registered the url address i want to use, would i have to pay anyone to set up or register the name? or can i just use it?
i think i would need to have a server and/or networked drive on my computer and have the computer/drive/server in my house online 24 hours a day. is this correct? any idea how much a minimal set-up might cost? could you do it for a fairly low trafficked site with a conventional 1.5 to 2.0 Kbps DSL home telephone line? what else would i need to know? any good websites out there with a decent primer on how to get started?
thanks for any input.
Someone smarter/more experienced will follow on, but here’s what I know:
You will need to register and pay for the domain you want to use (blankety-blank.com would be funny, and is available FYI).
You can host it from your place in essence for free (minus electricity), there technical limitation will be the speed that your ISP allows for outgoing transmissions. Typically you can download at 1mbps+ rate, but the upload will be like 200kpbs. So if you’re serving up lots of files (pictures, videos etc) then you will notice this performance issue.
However, I think FIOS (by Verizon) offers a good upload rate. And some of the telephone DSL “business” services offer great upload rates, and I’ve seen ads for biz services that cost the same as my “home” service.
There are lots of good sites out there. When I did this I used L.A.M.P - Linux, Apache, MySQL and PMP for my site. I used a RedHat Linux computre (purchased used from a company and it had Windows, I wiped it and put on the free Linux). Apache was the web server software, it is open/free. MySQL is a free/open database, and PMP was the coding language for the site.
You can also find a lot of open custom code that will do user registration etc, if that’s what you are going for.
It really will depend on what you are trying to do. If you are doing this for a business, I’d recommend a service so you “know” that your site is up and running.
I have three personal websites and the thought of bring them into my home occurs quite often. FWIW, I manage a half a dozen webservers for work.
For your domain (www.whatever…) to map correctly to the server in your home, someone (you, or your ISP) needs to enter the appropriate DNS (domain name server) entris. The DNS entry just maps the IP address to the name. Now, here is where it can get sticky. Most DSL lines use dynamic IP addressing, which means that the IP address you and your computer have may not be the same from day to day. I use a $20 AT&T DSL line and have noticed quite a bit of variability in my IP address. Obviously, you cannot map your website to your server at home if the IP address is changing all the time. So…what you need is a STATIC IP address for your home. From what I can see, with AT&T, this jumps the price up considerably…into the $50/month range. Suddenly, this is not so cheap.
So, that would be the first question I would ask of my ISP…is my IP address static? If yes, great. If no, how much does it cost to do that? Once you have the static IP, mapping the domain name to it and getting the server running inside your home is another topic… :slight_smile:
One thing to keep in mind, running your own server costs electricity and opens you up to all kinds of security issues. Plus, a server at a data center will be far more reliable and faster.
Sure it is possible but it’s hard to beat $5 mo considering an ISP will give you 99.99% uptime without you having to do anything.
http://www.icdsoft.com/
I’m pretty sure that your ISP will have something to say about you hosting a server, and it will be expressed in extra $.
You can also use a dynamic dns service, e.g., http://www.dyndns.com/services/dns/dyndns/ to resolve the IP address problem. Basically, you tell these folks your IP and it remaps your domain name to it. When your IP changes, you send an update to the site (and this can be done automatically) and the linkage changes.
Whether or not you want to do this or not is another question. It may be in violation of the terms of service from your ISP, especially if it is for a business and you have a residential account. If you get a lot of traffic, it is more likely to be a problem.
Webhosting might run about $7 a month and can include free domain name registration, etc. See, e.g., http://www.bluehost.com/, which is what one of my friends who does professional web design uses for some of her sites. You get a lot for the money: you can have multiple domains for no extra fee, a lot of space (they just increased it to 200GB… jeez. I’m going to have to sign up). You also don’t have to pay for the power or worry about the uptime/downtime as that is what these people do for a living.
Depending on what you want to do, you can also use a place like http://wordpress.com to set up your website. I know the focus on their mainpage is blogs (blech), but you can set it up for many more things. I think Wordpress will then use your other host account to serve the content. I don’t remember all the details, but I have some friends who do this.
If you really want to configure your own LAMP or WAMP server, it is much easier to do these days than it used to be. But it all depends on your level of experience and how much time you want to spend doing sysadmin. Personally, I’d rather pay the $7 a month.
Perhaps you could share a little information about what you are trying to accomplish…
“Hosting a website” is fairly generic, but explain what you are trying to do with the site (share information, post information, access remote information, blogs, ecommerce, etc).
Thanks to all for the info and advice. all of it is very useful to me. generally, my thoughts are to host a few of my own web pages (primarily public access, not really for remote access), share test, a few photos, and small videos via that website, and also to do a small to moderate amount of e-commerce, i.e., sell some things off my website.
