I haven’t biked indoors using watts until yesterday. I decided to go ahead and set up the garage in prep for this winter (a few months ahead of time).
I was doing 4 x 5 min intervals and I had a difficult time getting my normal watts. Outside those intervals are done at 225 - 230 watts (I am 138lbs for those curious about such things). The watts I was able to generate with my setup was 180 - 190 watts - actually I must say that the indoor 180 watts felt tougher but that may have been because of the heat in the garage.
Trainer - I am using the standard Cycle Ops trainer - I think it is the CycleOps Magnetic Bike Trainer version - so their lower line. I cranked it just about as tight as I could.
Any suggestions or maybe some people can share their indoor setups.
Funny - I set my trainer up yesterday on a black track so I could do some brick work and noticed the exact same thing - higher percieved excertion for lower watts that the road. It was super hot here yesterday so I guess that cooling is really an issue.
Definitely get a good fan…and set up inside if possible. It may take awhile, but you ‘should’ be able to eventually approach similar sustained watts indoors. At least, that is what I have found on all but the highest wattage workouts. So, if it’s 8, 10, maybe 20 minute intervals, they are close indoors and out.
