Water bottle cage screw stuck
Howdy y’all,
I removed my water bottle cage for a sprint race and was trying to put it back on for an oly this weekend but one of the screws has lost its thread for the allen keys. It’s bascially just worn away, but it is still screwed on. So I can’t put my water bottle cage back on.
I tried lots with the allen keys but they won’t work - there’s nothing to press against. What should I try? Suggestions?
Thanks!
If the nut is slightly protruded outwards, you might have luck using a set of pliers to unscrew it. Otherwise, take it into the store, they should be able to look at it for free?
Dremel. Cut a slot for a flathead screwdriver…
The dremel/screwdriver trick is a good bet. Maybe for a little less effort, you could tap in a slightly larger torx head w/ a hammer to gain enough ‘bite’ to unscrew.
Thanks everyone for your replies - I was able to get it out with a vice-grips. It nearly wouldn’t budge though.
I’ve learnt my lesson!
