any solution to the gripper being too tight? Its the Voler Tri Race shorts http://www.voler.com/products.aspx?CID=4&PID=16
I wear medium but around the gripper it leaves a mark on my quads from the gripper because it is so tight, size up will be too big around the waist and
I can’t change brand as they are team shorts.
any ideas? Can the gripper be replaced / loosened?
This is a common problem. I run a garment repair and alteration business that can help.
I would have to replace the elastic with one that was slightly larger,there usually is not enough room to make the old pair bigger.
Let me know if you would like to try this. I have been doing this for 10 years. I run a add in Velonews if you would like to check it out. www.velonews.com/classifieds
