Vittoria Pit Stop with Zipps
Has anyone used Vittoria Pit Stop to fix a flat on Zipps with valve extenders, and if so, did it work???
bump, cuz I’m curious,too.
it works fine with a valve extender
I have with the zipp extender (which I normally don’t use but had a on-removeable core). It would have gotten me through a race as is considerably slowed air loss. In the long run, even pumping it back up w/ air (the cartridge has butane I think) it still lost a lot of air overnight. So ok for small fixes in the short term and no problem with the extender as I later removed it and just blew it out, very little inside and no problem with clogging.
Kevin
Thanks for the info, Kevin… I’ll keep carrying it and see what happens!
