Vetta V100 cadence sensor problem
Hi,
Anyone using a Vetta V100 have problems getting the cadence to work? I have tried a new battery, made sure the battery is in correctly, checked magnet alignment, used a bigger magnet, and checked placement of the sensor on the chainstay. Any ideas???
Thanks
Is your computer mounted such that a direct line of sight is blocked between it and the cadence sensor? I had to fiddle with computer positioning before it would work. But, I ended up mounting the wheel speed sensor on the back wheel, and the computer wouldn’t pick up the signal until I mounted the computer on the top tube! It really works well here. I put it where my knees don’t hit it, and now my Ouzo Pro Aero Forks are clean, too.
