Trying to cable 105 brake calipers. I have new jagwire cables together with the little metal sleeve that fits over the end. Problem is when I try and insert the cable housing and sleeve into the tension adjuster on the brake caliper it won’t fit. MY best guesses are:
the sleeve needs to be crimped on to the brake cable first (it’s currently kind of loose)and the crimping will reduce the diameter enough to force it in there;
the thing that looks like it might be a shim inside the tension adjuster is and can be removed by doing ____ after which the sleeve will fit no problem.
Am I close? suggestions gratefully received.
Ben
