do any of you use HR as a pacing guide during races?
yeah, I’ve used it. my heart rate follows a fairly predictable pattern during races.
start-spike
getting into groove- dips a bit
picking up intensity- gets jacked up
finish-explosion
well, that’s if everything goes to plan.
Not during races, but all the time while training. I have worn a HRM during races before but found it was too much gear and I became too focused on it. I prefer to just “listen” to my body at that point in time.
Have used it for IM races but does have some limitations. Im going to get a powermeter and use it next HIM and IM and see if this is better than using HR only. Hr varies too much depending on what part of the bike, fuel status, heat, and does tend to drift up longer you go with the same effort “cardiac drift”, i would think powermeter is easier to maintain intensity through all of these factors. We’ll see…
Yep,
IM: 75-85%MHR
HIM 80-90%MHR
Marathon 80-90%MHR
Half-M: 85-92% MHR
10K: 90-95% MHR
5K: 95-100% MHR
Hope this helps.
Alan
Me and another guy in our running group do.
I’ll tell you what, it can be a demon beast, not just some kind of nice reminder that you are going to fast for an aerobic pace—using it to run ABOVE A HEART RATE LEVEL.
I was under the misconception that all it was good for was making sure I stay on 70-75 percent Max HR. So, you know, whenever I have the HR reading going, I’m in a good mood, because its AEROBIC DAY!
That’s just its nice side. Its got an evil brother, and that is making sure you aren’t loafing on faster runs.
Use it for LThreshold runs.
I decided to use it to run on or slightly above 92 percent MHR, for LT tempo runs, which is 164 bpms for me. Let me tell you keeping it on or above that f&*kcer for 45 minutes IS HELL. I noticed every quarter of a mile in every 2 miles, I wanted to rest ever so slightly: and that my heart rate would drop to 156 or something. So, its time to pick it up. The game is never to let it sink below 164 BPMs for me, and it is a BRUTAL BRUTAL BRUTAL beast.
It may be the hardest run of your life.
I discovered I wasn’t running hard enough THE WHOLE WAY from that HRM for tempo runs.
HR measures the response to the pace you are running. Due to the variable nature of HR, day one at 160 may be faster or slower than day 2 at 160. If you learn pace you know the exact speed you need to run vs running a variable speed to maintain a response mechanism.
Be careful. Last race I ran was in the rain, and I had a whole lot of stress getting started (got lost driving, almost missed the start, no warmup, etc…). My HR was all over the place, most of the time it was about 10 beats faster at my goal pace than it was in training. I was fine, but my HRM told me I was in the red zone - not reliable at all. It’s great in training, helpful in racing, but don’t depend on it.
-Brian
Let me ask you this, Brian and some of you other real fast, good runners and triathletes.
If I said, go run a seven minute mile, and I didn’t give you a watch, how close could you get to nailing it right on a 7.
And then a 6?
And so on. How close can you guys nail it right on the money, with no watch.
I don’t see how you do it other than just building up a bank of running.
I did 30 min tempo on the track last March. every lap was between 1;29.5 and 1;30.5 except for lap one and two which were 1:33, 1;31. In college, I could routinely guess +/- :03 per mile how fast we were running on our normal loops.
most people have 3-5 loops that they run consistently. Establishing a few time checks then taking you recent race results and figuring uot how fast to run in training is not that hard. Figure out when you should hit the time checks in for different paces and you can tach yourself to dial in a pace rather well.
thanks for the input so far,
i guess after reading this stuff my question is:
is it a smart/safe/good idea to use HR as a goal and let that determin pace?
or should i stick to just using it in practice as an aid in my training?
thanks guys
“is it a smart/safe/good idea to use HR as a goal and let that determin pace?”
No
“should i stick to just using it in practice as an aid in my training?”
Yes
I think that some people just ‘get’ pace and others don’t. It is certainly something that can be trained and a track or good road course is a good place to do it.
I don’t think that HR is a good indicator of pace as several have indicated. It seems like you can wake up on the wrong side of the bed and it be off 10-20 beats during exercise. Perceived exertion/pace is certainly the way to go when training the run. A HR monitor could be used as a guide, but I wouldn’t be a slave to it.
thanks,
got in an argument with a friend today about it, i just won:-D
