Using an AT test to determine training zones
So I got on a treadmill about two months ago and did an AT test (as outlined in the Triathlete’s Training bible)
I started out at 7.6mph, and increased .2 every minute and measured heart rate. Here’s what I got:
7.6 144
7.8 160
8.0 161
8.2 166
8.4 169
8.6 171
8.8 175
9.0 177
9.2 179
9.4 182
9.6 185
9.8 186
I did the same test yesterday, and I went much further - I didn’t stop until 10.6mph, and my heart rate was 179. My weight was the same each time at 180 pounds. I’m now thoroughly confused. I know I’m in better shape now, because I was able to go faster without my heart rate getting as high, but how do I use this data in determining workout intensity? What was my AT according to these results?
Do you have RPE for the test and did you sujectively identify the point at which VT occurred?
I can’t really understand RPE. I started out at a fairly easy pace, and went until I couldn’t go anymore.
Without RPE or VT, there isn’t much you can do with that except what you already concluded.
I’d check out a local university nearby and get a good VO2 max test done a treadmill. It will give you the info you are looking for to set up your zones. Because what you have posted tells us absolutely nothing.
Did you warm up? This jumps out at me:
7.6 144
7.8 160
even cheaper…run a half marathon or a 10km hard and you will get very reliable data …i have seen to many suspicious vo2max test done…you never know if the machine are well calibrated…
true dat…plus here are a few articles to debunk this “conconi” type test.
http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&db=pubmed&dopt=Abstract&list_uids=15320666 Conconi Test - There is no evidence that one of the most popular heart rate tests, the Conconi-test or the Conconi deflection point, represents the lactate threshold. As shown in the next graph, the speed at the Conconi deflection point (Conconi threshold) differs clearly from the lactate threshold for this group of runners (if both thresholds would be identical, then all points have to be located on or near the diagonal line in the graph). Similar results were found for swimming and cycling even when the new adjusted Conconi test was considered in the study. http://www.lactate.com/triathlon/trwhy.htm I like the field test that the great jonnyo recomends. Kurt
Perhaps. But most university labs are pretty decent. Also, I’d wager the “numbers” he gets (who cares about absolute VO2 max) would be better than a field test though that has far more variables than a controlled VO2 max test (even run poorly). If he is looking to define training zones (i.e. zone 2 limits for most running, AeT, etc.) then you need this as well as estimating your upper zone 2 is tough from 10K race AT.
1 minute also doesn’t get you truly to steady state on the HR’s. I’m guessing the HR was still going up at the end of each minute still. Personally I believe in using each training session to monitor aerobic threshold and things like that. You’ll learn where you are on the curve pretty quickly just by listening to your body (Hence RPE Paulo talked about).
well…you are right…if you get a really go university or medical institute to do the test, it will most likely be reliable and well done. But i saw a lot of really interesting ‘‘Lab test’’ and even poorly given…and they number that came out of it were useless…
I understand some people prefer more accurate and precise data. They might need them… but for a everyday athlete like me, a field test is all i need and you get very very reliable data if you put a honest offer in the test… so that would be my way to suggest a age group athlete to save money and get some good zone establish out of a half marathon or 10km.
I’ve not tried this test, but here’s a website that compares it to other methods and gives an Excel file that you can use to plot your data from the treadmill.
http://www.brianmac.demon.co.uk/hrm3.htm
