Received my wheel from order 10, and noticed the rim tape was not pre-installed which means I can either try to install it (seems like a bitch to get it over the rim!) or use a selfadhesive cotton rim tape. What’s the experience with the Flo rim strip - good, or might as well use a cotton tape? All my other wheels have had cotton rim tape which has always worked very well - hence the question.
One of those things I didn’t even think about switching to latex on my race wheels. Are there any other “doh” moments? I’m now up to latex with removable cores, velox rim tape, Bontrager TLR sealant.
I just received flo 30’s from this last order and they had rim tape pre-installed. I chose to use it, hope I don’t regret that as I know nothing about different tapes.
We race on HED Jets, similar to the Flo wheels in that they are aluminum rims with bonded carbon. We have settled on using Stan’s tubeless tape for our wheels. Two layers of the tape seems to work well. When we used the Velox tape, it was good, but seemed to bunch a little bit. That was even after a thorough cleaning of the rims to make sure there was no oil/grease/etc.
I’ve had good results with Stan’s rim tape on my FLO 60/90 set. Two layers. Works really well with latex tubes and it’s thinner which seems to make installing tires easier.
Squirming is not an issue if you use the appropriate width of Velox. For the HED C2 wheels and most other wide wheels the 22mm (MTB) Velox is a perfect fit between the hooks and doesn’t move. The 16mm ‘normal’ stuff will cause you problems.
I was thinking of ordering some 19mm velox for my FLO’s…? 22mm seems like it would make it tougher to get tires on…
I don’t think he is referring to stans stuff specifically, I thought he was referring to the ribbed type packing tape(fibers run parallel to tape) would not be first time I was wrong if this is not what he was referring to once upon a time.
