Uninstalling Powercranks
Model 4 Standard. Okay, you take the dustcover/lockring things off, that allow you to take the crankarms off.
now what? do they just pop off the spline BBs? they don’t seem to. but it seems they should.
what now?
I’m not sure which model you have Dan, but are you not suppose to use the “dust cap” as the the “built in crank extractor” ?
Is this any indication that we might get an official Slowtwitch review of PC’s?
what now?
http://www.powercranks.com/newsite/Multimedia/Installation.pdf
Dan, Leave the dustcap/Lockring in place, and loosen the 8mm crank bolt. Basically, use the dust cap as the crank extractor ring. Otherwise, you’ll never get the blasted things off.
Dan,
With model 4 you need to use a crank puller on both sides. Keep the cranks on (and the chain and chain rings) so you have something to apply counter torque.
Frank
“Basically, use the dust cap as the crank extractor ring”
i don’t think that works with powercranks.
It did with earlier iterations, not model 4. I changed because we got lots of calls from bike shops asking how to remove them so I changed the design to be more traditional. Guess it still isn’t obvious though :slight_smile:
