Unexpected side effects. Part 1 - compact cranks
Great! Now I am even more confused. Can anyone simplify this stuff?
Last year I switched out my standard cranks’ rings to the smallest I could find for 130s - 50/38, 11/23 on 650s. I LOVED IT. My riding improved immediately. Prior to that I was on a 53/39, before that a 53/41, each time I dropped the tooth count my riding improved.
This year I bought a bike with big boy wheels (700s) and put compacts on it - 50/34 with an 11/23. Still love it. I find the jump between 50 and 34 to be too big of a jump though, so I’m moving to a 36 and a 12/25, as I never use the 11 anyway. My riding has improved dramatically since getting off of those big gears.
…nor am I aware now of any BIG rings smaller than 50T for 130BCD.
You can go all the way down to 46 with 130mm BBCD.
FSA
130mm BCD - PRO ROAD CHAINRINGS http://fullspeedahead.com/images/bullet.gif Outer Sizes - 46, 48, 50, 52, 53, 54, 55T http://fullspeedahead.com/images/pixel.gif http://fullspeedahead.com/images/bullet.gif Inner Sizes - 38, 39, 42, 44T
http://fullspeedahead.com/fly.aspx?layout=product&taxid=25&pid=66
I stand corrected. But it didn’t matter for me, as it was the small ring, the 38, that I couldn’t get small enough in a 130BCD. Even on my compacts I still run a 50T.
Like I said, you can even put a 38 on as your big chainring…it just won’t be ramped, but it still works.
Now you guys got me thinking maybe I should go to a 48/34 11/23 instead of a 50/36 and an 12/25, because I don’t like the big jump from 50 to the 34.
That might be a wiser choice, indeed.
depends on the cranks. cant do that (46-48T big ring) with a standard shimano 130BCD or campy 135BCD. need the compact (110BCD) to get below 52T.
Ummm…excuse me? I was just using a 48T Qring for the big ring on my standard FSA aluminum cranks. These are easily found, as are 46T or even using an inner ring as the outer as devp mentioned. www.qbike.com is a good way to search.
Regarding the change from 48T to 54T on my race bike, I am only making that change because I was spinning out the 48/11T at about 34-35mph on fast sprints. With the 54T I can keep it going at 100rpm up to nearly 40mph before I start getting out of the “power band.” For training it also puts my “fast interval” gears in the 13-17 range in the back at 22-28mph. With the 48T when I was haulin butt I’d end up in the 48/12 with a big step in rpm for the same speed going to 48/11. I.e. 92rpm in 48/12 is ~29mph but the next gear up would put me at 85rpm, which is way too big of a jump.
Okay, what is ‘‘ramped?’’
There are times that compact is just not enough… I was riding with an aggressive group, and somewhere on a flat terrain, I was on my big chain ring (50) and smallest cog (12) turning around 88rpm speed was about 46kph and I still couldn’t stay with the pack… well that’s the Donut ride!!
You are correct. I can sometimes barely keep up with the roadies flying downhill in my 50/11. With the 48 it’ll be even harder, but the rest of the time…
**Has anyone mentioned that snap some riders like their rings and cranks to match? Mixing and matching doesn’t work for snap everyone. **
I went Shimano compact on my road bike for three reasons: I wanted a 34, I wanted to drop my big ring, and I wanted everything to be silver and not ((((((((((((shudder))))))))))))) carbon.
What is the snap thing?
I would like to go with compact, but with my components being 5 years old, I am not sure which crank set to go with. I find the swapping of the chain rings to be easier, and less expensive. What do you suggest?
I got a new bike last year with compact cranks and love them. I’ve agree with everything you’ve said.
In swapping out a 53T ring to a 50T or a 48T, what kind of adjustment do you need to make to your front derailleur? Does it need to be lowered and is that fairly straightforward for a bike idiot like me to do?
Just a couple of teeth and you probably don’t need to make any adjustment. If you want to though, it would need to be dropped to retain the same amount of clearance. A big thing? Not really but it will probably require you to remove the cable and make the adjustment (take up the slack) thereafter. You can’t get in a lot of trouble here.
you’ll need to drop it. I would be surprised if you didn’t have rubbing if you don’t. IIRC mine dropped about the FD band width going from 53 to 50. I’d use the park tool website instructions as your guide, but its not too difficult, just may take a little while if you haven’t done it before.
  1. undo the cable fixing bolt (wont be able to drop with the shifting cable still taught)
  2. drop the dérailleur
  3. reattach the cable
  4. ensure stops (H/L) are still correct, and that it shifts properly (including trim). I’d be surprised if you didn’t have a little tweaking required.
*The 53x12-14 are totally useless gears for most of us in triathlon…if you are going 60 kph, you may as well coast and save the legs for the run. *
sure, that makes sense for when you’re actually racing, and it makes some sense for when you’re doing a brick.
but the overwhelming proportion of the times that I get on my bike and go for a ride, there’s no run afterwards. All I’m saving my legs for is the sofa.
I’ve got a 50-36 now, and overall I’m happy with it, but I do miss the 53x12 on the downhills. I can’t imagine going any smaller than 50.
If you drop to a 48 or 46 don’t plan on doing fast group rides. You would get dropped around here. I use a 50-36 with a 11-23 on my tri bike and that works well. For my road bike I am going to switch to 50-38 this winter. I agree that most people are overgeared for most situations. Years ago I switched my wife to a 50-34 and that really helped her enjoy cycling more. I might even move her to a 48-34…
How fast are your group rides? I have a 48x12 and I can keep up even when the group is mometarily going at 50-60 kph? Tyler Hamilton road the 2003 TdF “group ride” with a 50/34 and had no issues (dope or not). In fact, on one stage with his girly man 50 tooth chainring he road for 4+ hours off the front of the Peleton? Is your group ride 4% slower (in which case you can keep up with the 48) than the TdF group ride/peleton? :slight_smile:
…or maybe you guys need to learn to spin…I guess lots of you guys feels like manliness is tied to the size of the large chainring :-).
I sometimes do group rides on my 'cross bike. My largest gear is 46x12 and I don’t have a problem keeping up. 46x12 @ 120rpm is 58kph.
