I’m a road racer who may need a UCI compliant bike for certain events, stage races and time trials. I’m just about done building my new bike, a Cervelo P# Carbon in size 61. I’m a little over 6’,3". I was fitted this morning and feel pretty good on it. Here’s the issue. I comply with the saddle 5 cm back from the vertical line from the center of the bb, partly because I’m now using one of those snub nosed Adama saddles. So, that is good.
The issue for me will be getting within the parameters for the distance from the verticle line/center of bb to the tip of the aero extensions. Since I’m tall, I should easily qualify for the morphological exemption to go from 75 to 80 cm from that imaginary center of bb/vertical line.
Right now, I’m pretty dialed in fit wise but I’m at about 83 cm. So, 3 cm too long. Plus, I have the aero bar extensions that curve upward. My fitter told me I also have to watch out about being disqualified if I’m too close to the “praying mantis” type position that Floyd Landis used to use before it was outlawed, i.e., the one where the arms are tilted way up so that they almost touch the chest. My arms are fairly flat as compared to the praying mantis so I’m not too concerned about that but my fitter said I would be better off going with straight aero extensions.
Anyway, I could use a much shorter stem than my current 110. Maybe go to an 80? Or get straight extensions and cut them shorter. Either way, I have a feeling that I’m going to feel cramped.
Any tall guys out there that have suggestions for dealing with all this bureaucratic UCI hassle? I’m hoping that if I finally get this dialed in and compliant, it will be somewhat comfortable. If I’m going to the hassle of buying new bars, rather than just getting straight extensions, I might as well get bars that comply with the UCI 3/1 rule.
PS - I have a feeling my older Oval bars are non-compliant as to 3/1 and I’ve also heard some rumors that stock Cervelo seatposts also violate the 3/1 rule. That’s another headache.
