And why your front brake? That sounds extremely dangerous… if you’re doing only one brake on your bar-ends do your rear brake. Next time you’re flying along grab your front brake only and see what happens! OK… once you’ve picked your carcass up off the tarmac and gotten out of the hospital, come back and post about your case study.
Biking basics: Front brake has more overall stopping power, but as others have pointed out the rear brake provides more control.
(Ok… since Coggan/Oracle isn’t here, I’ll do my best impression:)
Okay, since you don’t seem to get this… I’ll give you a hypothetical test to try:
Trial 1: Ride at speed on a flat or downhill stretch at a reasonable rate (15-25 mph, or faster if you’d like). Apply your rear brake vigorously. See what happens.
My experience is one of two things… Either 1) Rear wheel locks up and I can control the stop or more likely 2) I feather the brake so that it is even easier to control the stop
Trial 2: Ride at speed on a flat or downhill stretch at a reasonable rate (15-25 mph, or faster if you’d like). Apply your front brake vigorously. See what happens.
Unless you are using an extremely weak single caliper brake that isn’t calibrated correctly you’re going straight over the handlebars.
I would agree with others that if you’re on a fixed gear then the front brake becomes important. However, to suggest that anyone use a front brake as the primary emergency brake is just plain dangerous. I don’t care how good one’s bike handling skills are, that’s a one-time lesson learned the hard way.
Okay, since you YOU don’t seem to get this… I’ll give you a hypothetical test to try:
Trial 1: Ride at speed on a flat or downhill stretch at a reasonable rate (15-25 mph, or faster if you’d like). Apply your rear brake vigorously. See what happens. Rear locks up… depending on tires, speed and road surface rear end goes out once or through several oscillations … good bike-handler countersteers … bad bike-handler high-sides or low-sides My experience is one of two things… Either 1) Rear wheel locks up and I can control the stop good bike handler with heart in his throat as he narrowly misses the heavily-laden truck who doesn’t see him or more likely 2) I feather the brake so that it is even easier to control the stop The latter is not a consequence of applying “rear brake vigorously…” and you won’t stop for shit
Trial 2: Ride at speed on a flat or downhill stretch at a reasonable rate (15-25 mph, or faster if you’d like). Apply your front brake vigorously. See what happens. Bike stops, heart where it belongs
Unless you are using an extremely weak single caliper brake that isn’t calibrated correctly you’re going straight over the handlebars. No
well, this might be a good area for coggan to chime in on. I’m not sure who he is on this forum, but he was quite the tt’er and i’ve seen pictres of him on a hooker with just aero bars. It would be great if he gave a detailed explanation of his thoughts on front and rear braking and the aero position.
Also, Andrew Coggan, if you indeed post here and don’t mind pm’ing me, drop me a line, i ran across a forum posting from 2003 on a different forum, and while it’s a little late, i might be able to help you with something.
Why are you so afraid of getting the rear end a little loose? And why do you insist that the application of the rear brakes will lock up the rear end? And even if the rear end locks up; any decent handler should be able to handle it.
