Training those systems…the gluconeogenesis and fuel ingestion systems, along with increasing the slowtwitch mitochondria?
I don’t know that those are systems that can actually be ‘trained’.
JC wrote: I don’t know that those are systems that can actually be ‘trained’
yeah, that’s why in the original post, I stated that this LSD proponent theory is often put out there like that…that you are training the systems. By training, I take it to mean that necessary enzyme systems are better able to meet the demand, there is an increase in mitochondria in the muscle cell…specifically the slow twitch cells in this case. At any point, the idea that the system can actually respond to “training” may not be valid. However, there is obviously a large number of people that have good results with LSD training.
SO, something is responsible for producing these good results…if it is in response to better handling energy supply as a training result of a relative low level of available glycogen…would pre-burning some of the glycogen (by using the glycogen-thirsty fast-twitch fibers more than usual in a typical LSD session.) allow the training effects to be manifested as outlined with less time required?
I don’t know…just wondering what people think.
One potential argument against this is that by doing a hard set first, you won’t be able to get nearly the LSD volume in as compared to starting the LSD fresh.
Specifically, for those of you that adhere to this way of training, why wouldn’t it be a good idea to burn a lot of the available muscle glycogen with the fast-twitch system early in the workout, then finish by doing the bulk of the workout at low intensity? Wouldn’t this force the slowtwitch energy system to be even more gluconeogenic?
No, and no.
And as long as you are going slow enough after the hard section, wouldn’t you still be able to continue to exercise for as long as usual by utilizing the slowtwitch muscle fibers?
No.
Why? Longer answer: Because your body does not work and perform like a combustion engine.
jhc, I know you might not be able to get in as long a slow pace distance…but, I guess this goes to the heart of why we do long slow pace distances anyway. If our LSD training is trying to make the slow twitch fibers and their energy systems work more effectively, why wouldn’t putting them in the somewhat glycogen and fast-twitch depleted state sooner by using it up at the beginning? Then, maybe you don’t have to do as much time in the LSD state. After all, perhaps it’s not the first two hours of LSD that give you the training benefits you are looking for, but, it’s the last two hours…I’m trying to guess if we can shorten that first two hours…
It’s a good question… no doubt you would require greater hepatic gluconeogenesis, so maybe that aspect could be trained more efficiently. However it’s also possible that if you were in oxygen dept after the hard phase you wouldn’t be able to train your muscle aerobic systems optimally afterwards.
Yaquicarbo,
My understanding is that if you do your hard stuff first = burn glycogen - then try and do LSD - your body will not switch back to fat quickly or well. Once you go hard - I think your body has a hard time switching back - hence the rule to avoid spikes in long races…
I was taught that if too high a % of your training is higher intensity - you will become more of a glycogen burner and even at LSD pace will be burning a higher % of glycogen than someone who does more LSD stuff/less intensity. So train hard a lot and race long and you’ll likely run out of glycogen = bonk. Is this true? Probably but its just what I was taught. This of course could all be myth…
If you train high intensity first then go LSD - recipe for injury. Also may defeat the purpose of LSD? Try it and let us know.
A friend of mine who races really long (badwater) - says that after the bonk (running out of glycogen) - you get a 2nd wind = start of gluconeogenisis via breaking down proteins. I always thought that once you were out of glycogen - you were done for the day as you can’t burn fat without glycogen and your body will shut down hard and fast. Opinions?
Yaquicarbo - have you raced long, yet? I know you were doing well in shorter races - curious how your training translated into longer races. Are you doing a full IM, soon?
Dave
Dave, jhc, and Brian, thanks for your responses. I think Brian may have hit upon one perhaps the main reason not to do this kind of workout, increased consumption of protein. I think most everyone would agree that conserving protein is a better strategy.
I have experienced the “2nd wind” phenomenon after bonking…but, that was almost 20 years ago…haven’t bonked since! It was amazing how much you can recover in a relatively short period of time…it may also be interesting to note my first bought of tendonitis happened concurrently following that bonk…maybe a causal relationship there?
Dave, I’m still working towards my first Ironman on Oct. 16th. I haven’t attempted this proposed “work hard then go easy session”…just thought about it. I’m basically trying to scratch out enough time to do the LSD stuff, but, there are only a finite amount of minutes in the day, and I’m going to have to attempt this Ironman on much less training than the average person reports to put in. Still, I’ll be surprised if I don’t do OK…based upon the halves I’ve done in recent history. I know the Iron distance is another animal, but, I know it can be managed if properly respected. Usually, after a long workout, I feel that I can do the Ironman with no real problem. The nutrition/hydration/electrolyte balance seems to be dialed in, even in 90+ degree heat (which shouldn’t be a problem in October). But, a few hours later, the enormity of the effort begins to sink in, and I wish I had more time to prepare.
I realize I won’t be able to race this first one. But, I still would like to finish fairly high overall in my AG. I’m going to have to do it with being smart about it, not by being perfectly prepared. We’ll see.
Thanks again fellas, for bouncing this idea around a bit. We’ll just let it bounce on out of the room, I guess…too high a protein cost.
"Just wondering what the thinkers in the sport have to say about it… "
I’m offended! Are you implying I’m not a thinker, or just that my thoughts don’t count? ;-o
Jack Daniels advocates this type of workout for marathoners. It’s a good race simulation, in terms of keepin’ on keepin’ on when your gauge is on empty, and combining a threshold workout with a long day. Very efficient AND painful. What more could you want?
He does not recommend a steady diet of this, however.
Cuz wrote: Are you implying I’m not a thinker…?
Cuz, that was a typo…I meant to write stinker, not thinker! Thanks for your ideas!
Great question you asked, and I’m still waiting for someome to give an answer from a physiological point of view. The assertion that ypeople make that you shouldn’t mix up aerobic (LSD) training with speed training because you should focus on one or the other, sounds sensible, but where is the proof? My HRM doesn’t work very well at the moment, so I am just doing the distances in my program and making sure I can complete. I just did my PB in a half marathon by 12 minutes, by sticking to my program and not bothering on HR. The program follows traditional principles of building base (still in that phase now) then strength, then speed. Strength will be addressed by hills, and speed by accelerations or intervals.
I suspect the reasoning is more psychological/volume related. I physically can’t do long, fast distance at the moment, so long slow distance is the only thing I can do. If you want to have a build/recover cycle that covers a reasonable amount of time, you have to go slow at the start. Apparently we can retain the ability to go distance (base training) for longer than we can retain speed. I would be real interested in the physiological basis for this, and therefore how we can train to optimise this. In particular, I would like to know if the two systems have to be trained separately.
