Tuning, not easy
So I’ll be the first to admit that I’m not the most mechanically inclined person, but I recently installed a new garbage disposer and was quite proud of myself, so I thought i’d take a shot at tuning up my bike. I had a few gears slipping and it was pissing me off. So last night at 8:30pm I decided to give it a go. After determining that the barrell adjuster alone would not fix it I started with the h and l screws per park tool’s website. 1.5 hours later and several iterations and I was no closer then when I had started so I gave up.
Is it really that difficult or am I just a dolt?
Patience. Do it again, starting a little earlier in the day, and try to do only one fix at a time. For instance, if you play with the barrel one direction and it’s helping, don’t go messing with the limit screws until you’re done with the barrel. Try to remember how many turns of various things you’ve done, so you can put it back where it was and change something else instead. And, having a beer or two handy sometimes helps.
Good luck!
Dolt :wink:
I have not seen it in a while - but back in the day Calvin Jones (now with Park Tool) was teaching how to tune a rear der with no cable even on the bike - works 100 times out of 100. Too wordy for me to post now as my ADD is in full swing.
If all else fails, follow the destructions.
I’m a do-it-yourselfer and I’ve gotten pretty good at working with derailleurs and cables, but you have to play with stuff a bit before you have that “ah-HA moment” where it all makes sense. If it’s Shimano stuff, I highly recommend you download the pdf instructions from Shimano. I’ve found them much more useful than the Park Tool website. No slam at Park Tool, but they’re trying to generalize a bit for different brands and generations of equipment. Whatever brand you may have, try to find instructions specific to that brand. And when you find them, keep 'em around in a file.
One rookie mistake I kept making was trying to pull the cables too tight before I ever clamped them down to the derailleur. That messed everything up – especially on the front derailleur. They don’t have to play a high C note when you pluck 'em.
Also, be sure to check your cables up at the shifters for any fraying (road bike, especially). And check the ends of the cable housings to make sure they’re not cracking, fraying, rusting and getting clogged with corrosion, etc. Those things are easily overlooked and can cause shifting issues. The cable guides that run at the bottom of your bottom bracket can get all sticky from leaking sports drink, sweat and road grit. Then they can bind the cables so they don’t travel properly. Clean that area regularly and give it a spray or a few drops of lube now and then. You might have one of these kinds of issues that’s keeping the work you’re doing with the barrel adjusters and limit screws from yielding good results.
You’ll figure it out. Then you’ll feel proud.
You’re not a dolt, you just don’t know what you’re doing.
At least that’s what I tell myself when I swim…
Follow these steps, in order:
  1. Disconnect RD Cable
  2. Drip petro based chain lube into RD housings, slide back and forth
  3. Set limit screws. Lower screw adjusts top of travel, upper screw adjusts bottom. Or, high screw, high gear. W/ cable disconnected, top jockey pulley should sit just a skosh outboard of smallest cog. Pedal with right hand, and ‘shift’ with left hand, pushing der. to top of travel. Again, top pulley should sit just inboard of largest cog at limit of travel. MAKE sure der. will not contact spokes. Continue to pedal, slowly letting rear der. return to bottom of cog.
  4. Attach cable tip, if not already on.
  5. Set barrel adjuster to approximate center of travel (so you can adjust either way). Do both the one at the der. and the one on your cable boss on frame (if applicable)
  6. Grap cable beyond pinch bolt, inside of cable tip with pliers. Pull until taut, using right hand.
  7. Meanwhile, using left hand, attach cable to rear der. via pinch bolt.
If it doesn’t want to shift to a higher gear, you’re cable is too loose, and the cable pull is not overcoming the spring in the rear der. Tighten cable by turning barrel adjuster to left.
If it doesn’t want to shift down to a lower gear, the cable is too tight and not letting spring do it’s job. Loosen cable by turning barrel adjuster to right.
Adjust one ‘click’ at a time until it’s right.
Just like anything it gets easier with practice. Eventually you’ll be able to ‘pluck’ cable and tell if the tension is right.
Finally, take it for a test spin and make sure it shifts well under load in both chainrings. (Unless you have three, in which case you are a dolt) You can fine-tune while riding using barrel adjuster on frame. Turning adjuster ‘out’ away from frame tightens cable, turning in towards frame loosens. Same guidelines as above.
Clean bike with windex and wife’s dish towel. Discard evidence. Drink beer.
