Tubular Tires?
I’m looking for good Tubular tires that are reliable, fast and ride smooth…I have been riding the Zipp tires but they only lasted 3 shorter races. I have used Continental and they lasted longer, but they rolling resistance was not the best 2 years ago…I need some help to get new ones. Any input will help. Do you know what tubulars they were using at the Tour on most of the teams???
 define 'lasted'?  I've never seen a tire 'last' only 200 miles.  I'm not using the Zipps, but a similar tire (Bontrager RXL's) and I got over 2,000 miles out of a rear tire?  If by lasted you mean 'flatted', well, you could have the most durable tire in the world and have bad luck after 3 miles.  I think 'durability' and 'flat resistance' are two different issues.
Of the three different tires i’ve tried:
I like the Vittoria corsa evo cx II tires, they roll very well assuming they’re glued on correctly. For what its worth I’ve never had problems in terms of durability, although I’m pretty sure the Zipp tires that you say wear out quickly are made by Vittoria. Fairly standard tire, I think several pro tour teams use it.
I’ve tried the Continental Competition tires a few times on a friend’s wheels, didn’t really feel like they were anything special, although maybe I just didn’t ride them enough to notice. Several top pros in Kona use these.
From your description it sounds like you’ve been using Continental Sprinters, these are definitely not the fastest tire but they are super grippy, excellent for riding in wet conditions. Plus they’re nearly bombproof.
I’m not sure what you mean by ‘lasted’, but I get several thousand miles (assuming no flats due to sharps) out of my Veloflex Carbons and love the ride quality. I also have a set fo Gatoskins on my ‘Beruit Wheels’ that I have pulled several shards of glass out of after rides. They don’t have the same ‘feel’ and I definately prefer the Veloflex, but they really take a beating.
Conti Competitions. Love them. You will too. Buy them. Done.
Anything Schwalbe makes.
Ultremos if you can find them (let me know where) or the Stelvios (Duranos). Best tires on earth.
Tufo’s work great for me, I have them on most all my race rims.
