I have this new set of Zipp 909s. They’re tubulars. I glued up the rear wheel a few weeks ago and had no problems at all. I did the three-thin-layers-over-three-nights approach.
Last night I was on night three doing the front wheel. All was going well until it came time to actually mount the tire. I put a nice, clean piece of wood down on the floor and rested the wheel down against it. Starting with the valve at the top, I start stetching the wheel onto the rim … applying outward and downward force as I work my way around. It gets murderously difficult towards the end, and as I’m forcing the tire, the piece of wood breaks loose from the floor of my workshop and slides out. I go sprawling … face-first into my workbench. I come to rest on my stomach on the floor with my ridiculously expensive new Zipp wheel – that weighs about as much as a handful of paperclips – underneath me. As I come to my feet holding my face, the wheel is glued to my shirt.
With new-found anger and adrenaline, I ultimately got the tire on (just needed a bit less air pressure in the tire) and no harm was done. My face is a little sore.
All that and I now have a wheel that should only be slightly slower than a clincher which I could have put a tire on in about 3 minutes, tops. (I guess I’m having a problem with that clincher research. I think there are too many other variables in play. I’ll find out when the race season starts.)
This experiment proves conclusively that tubular tires are bad for your face. It’s not too late to save your face from permanent damage by embracing clinchers - but you must act now.
Bob,
Your efforts are commendable … and yes you will be faster despite the supposed studies of “fast” clinchers.
Why are you putting 3 layers of glue on??? I’ve done this for a long time and I think you’re making it too hard. A single layer application, wait til tacky … then apply a prestretched tubie and you should be good to go the next day for anything.
Changing a tubie on the road should be easy also. Just keep a previously mounted spare so it has some residual glue … strip off the flat and put on the spare/ zapp with a CO2 cartridge and you’re good to go. Should take about 3min or less. I’ve never had a good tubie ( i.e. conti comp) come off even with much stress when it was put on as a spare like above. To me there is a definite issue of what kind of tubie to use and I think you’ll figure that out for yourself after you have tried some of the different brands.
Dave
Dave,
There are lots of opinions on this. First, I’m not a triathlete … I’m a time trial specialist. (Why do I hang out here? Well … I think we’re like distant cousins 'cuz of our shared aero interests … and I do lots of tri relays.) I’m competing in races where every split second really counts and I hope in the year ahead to be doing so in some pretty high-caliber events. One of the things that’s supposed to cause relative performance loss between clinchers and tubulars is the glue “hystesis” (I think that’s the word) at the tire/rim interface. If the glue isn’t right, the tire and rim can move separately from each other and wattage is lost. Short of using track shellac which dries very hard but gets brittle, my research has led me to the conclusion that the three-thin-coats approach with a product like Vittoria Mastic One is a good way to go to minimize the wattage loss.
Regarding tire choice, I’ve raced primarily on Vittoria Open Corsa CX clinchers until now. I haven’t been too impressed with their durability and I’ve been nervous about using them in longer races on open roads. But they’ve seemed plenty fast to me. I researched tubular tires rather carefully. While there are faster choices, I’ve opted for the Vittoria Corsa CX tubulars because, of the top-performing tubular tires, they represent the best value and the tubular version has an added puncture-resistant layer vs. the clincher version. In some areas I’ll compromise speed characteristics for peace-of-mind 'cuz I think the peace-of-mind factor helps me push the “let 'er rip envelope.”
Bob,
You have reasons and rituals … thats what makes it fun!
Hysteresis is getting pretty high tech for me, but I do know a tight fitting tubie performs better. I have always thought it was more a function of the design of the tubie and the inflation level rather than just the glue. For instance I find a zipp tubie tends to fit looser and actually moves on the rim which I notice as even touching the side of the “wheelwell” on a time trial bike. They also fit on much easier when mounting, but I look upon that as a poor fit that I need to glue tighter to keep them running efficiently and in alignment. A conti comp mounts hard but to me stays true and doesn’t get drift on the rim. If I inflate them to a higher pressure, they also stay aligned better. I think there’s more to it than just glue hysteresis … but I admit I don’t know everything by a long ways.
Dave
I’m a reformed tubular rider which is kind of like a reformed smoker. . .
Tubulars are fast if (1) you bought a well-designed tubular known for low rolling-resistance. (2) The tire that was sent to you was actually round and true— Many aren’t, no matter how much you paid. (3) You installed the tire properly— With the right glue applied in the right manner with the tire properly centered on the rim. (4) Your spare tubular is wrapped up tight and tucked out of the wind on your bike. (5) You get one or fewer flats in a race.
Did you notice what Normann was doing in his 2005 IM Hawaii nervous breakdown— Trying to pry his tubular off of the rim. You could argue he lost the race because of the trouble he had changing his tires. Everyone seems to think that they will be able to get all 5 steps right but most people don’t.
The only reason tubulars are still around is because Zipp has not figured out how to make light carbon clinchers.
