Tubular Installation - getting it straight
How do I properly make sure my tubulars are installed straight on my new 2005 Zipp 909’s? :slight_smile:
I have always had a professional do it, but the bike shop isn’t opened at 9 pm and I wanted to try to do it on my own, and now it is , let’s say, a wee bit wobbly!
Thanks in advance.
I started using tape for this very issue. Tape goes on, tire goes on, center it up, pull the paper off the tape, and you’re done.
Less messy, too.
It seems to hold well, but I think about rolling a tire on the corners though. I haven’t tried taking one off, either.
I used Tufo Tape. Apparently, i am a jackass and don’t really know how to use it properly.
I guess you put the tape, and remore the protective layer it comes with AFTER installing the tire…Duh!
Thanks a lot in any case.
I used to have a whole article on this but can’t seem to find it. My personal opinion is to ALWAYS use glue, Tape is not 100% and I’ve seen too many tires with tape roll off. You’ll never see a taped tubular in a crit just for this reason.
Simple though: ALWAYS STRETCH THE TIRE OVERNIGHT Mount it dry on the wheel and inflate it to approx 100psi. In the morning, you want to still stretch it a bit by placing the tire under your foot and pull up on the tire, do this 360 degrees
Put a smooth coat of glue on the rim. I use a toothbrush to evenly spread the glue on the rim.
Next, put a smooth coat on the tire. Inflate the tire a bit so it takes shape. It will make it easier. IF you think you will need to do a quick transition with a flat, you can put a smaller amount of glue opposite the valve hole as it will allow you to take the tire off a bit easier.
Let both sides dry for approx 20-30 min or until the glue is tacky. Deflate the tire and put the tire on the rim. Inflate 15-20psi and spin the wheel slowly. Make sure the tire is on straight and there are no hops or wobbles in the tread.
Let it dry for 24 hours and you are set.
Any other questions, feel free to call. Advice is free
STeve H
www.buytrigear.com
610.410.8919
My main concern is to get the tire on really , really, I mean really straight.
I have state of the art wheels, and don’t think it makes sense to have them and a tire that is 1/8 inch out of true, wobbling all over the place.
I can put the tire on OK, never had trouble there. But I can’t get it straight as an arrow as the pro mechanics at my local shop.
I stretch the tire ona rim overnight, then apply a layer of glue to rim and tire side separately and let them dry independently. Then I add a layer of glue to the rim and put the tire on while it is still wet so I can still slide it around/center it. Seems to work fine and I think other articles promote this method.
Are you by any chance selling your old wheels?
Shoot me a pm if you are (i lost your email)
Old wheels long gone, young one.
Pre season is a great time to get new stuff, get rid of old ones.
I do have a set of Lew Sydneys ( with Zipp stickers) I am willing to part with if the right offer comes my way. They are 700c, incredibly lightweight and stiff.
Want them? PM me. I can send pics.
Thanks for the tutorial. I need this as I’m moving to tubulars for first time.
How do you prep a spare?
Thanks in advance,
Doug
you may want to mount it without any glue and center it as perfect as you are satisfied with then mark the tire along the edge of the rim. do all the glue stuff then use the mark to guide you when placing the tire onto the rim. hope this works for you.
If you use the Tufo tape…be sure you soak the cloth part of the tire with water BEFORE putting the tire on the rim, put the tire on the rim, pump it up to about 30 lbs (enough to give it shape), then its easy to center, since the water allows the tire to move around alittle. Then pump the tire up solid and ride around the block…DONE!
Paul,
I email Tufo about the water on the cloth trick. They said that you only need to do that with the regular Tufo tape. The extreme tape has a plastic strip on each side. You remove the tire side strip after the tire is on and straight.
The Tufo website has a video of the installation…
http://www.tufo.com/index.php?lg=en&co=instrukce#Instr6
Ron
I stand corrected. I’ve never used the extreme tape. I always use the regular.
Actually, I’ve been using the tape on my crit wheels for the past year without an issue. I couldn’t get the extreme tape at the time and just used the regular tape. The tires are stuck quite well. I’ve since begun riding on the track and have started using the extreme tape. Definitely a much improved product over the standard tape. I’ll “stick” to the extreme tape from now on! (The water on the tape thing did help with allowing some alignment before the tires were permanently stuck with the standard tape.)
Once you have put your tire on, inflate it a fair whack, and then simply just check that the tyre looks even. If not then you should be able to move the tyre around to even it up easily before the glue dries fully anyway.
I also always leave about 30cm of the rim and tyre without any glue at all opposite the valve for very quick removal. I probably use half a tube of glue for the rest of the tyre and rim. Which is heaps, and I have never rolled a tyre off the rim.
I always reglue my tyres a few days before a big race. To ensure that the glue is refresh and I can quickly get the tyre off if required. There is nothing worse than trying to geta tyre off that has been glued on for a lonnnnnng time.
