Ok…so last week I had a race…and then did a training ride on my race wheels. Too lazy to change back to my training wheels…and too stupid.
So of course I flatted out.
But here’s the thing…I managed to change the flat on the road. I got the wheels used and they can with these tires…so I had never tried to change a flat tubular before. Well this guy apparently liked glue. The hardest part was ripping the wheel off.
Well I figured this week I’d rip off the tire and get everything cleaned up and situated now that I have a few weeks off of racing. I thought it would be a good chance to stretch out my other spares.
But here’s the thing. The new tire is on there perfectly…and the glue that was already stuck on the rim is really sticking good to the tire.
Is it bad if I just leave that tire on there? It sure as hell ain’t going to roll off.
depends on your course type. In tri/tt type of strainght races I will leave. Just deflate the tire try to remove it if it doesnt come off very easy then leave it.
best practice would be remove the tire clean the rim and put a little new glue.
you might be best off with a coat of glue on the base tape, then a little thin coat on the rim to activate the existing cement and give you a nice bond, I’d let the stuff on the basetape dry, but it’s OK if the coat on the rim is a little sticky. It doesn’t take more than 5 mins to do and will give you confidence in your wheel.
If it’s really stuck on there good, then why would you work harder to get it stuck on there good?
Yes, leave it…as long as you’re sure. As stated above, the way to determine is to deflate then play with it. Also, make sure it’s stuck well all the way around not just in one place.
no chance i’d ride a tubular like that, which isn’t properly glued. just because it seems like it’s on there doesn’t mean it will roll. if the tire has some miles on it and is already stretched then it will be pretty easy to glue and re-mount.
I flatted out.
I had a good spare with me. It was un stretched. THe old tire had a good sized puncture.
So I got the new tire on there…surprisingly it was a perfect fit, no lumps or anything. Ran smooth, it was great. Beginners luck.
So a few days later I went to try to get the tire off there so I could clean it up and do it properly and realized the old glue was stuck on there really good. I was really struggling to get a grip on there to rip it off there. I will certainly check the entire wheel when I get home to be sure…but in all honesty if I flat this tire at IM Moo…it will take me a few minutes of really good effort to rip this tire off of there.
Based on that I am thinking it’s probably good to go and I can leave it. There is no way it’s going to roll. I just wasn’t sure if that might be bad for the wheel or bad for the tire in some way.
are you basing this on the tire being inflated or deflated? because even with no glue on the tire or rim, the air pressure alone will make it feel like it’s stuck on there.
but either way, suit yourself. as i stated before, there’s ZERO chance i’d ride a tubular that isn’t properly mounted, meaning new coats of glue on BOTH the tire and rim. it will take you about 20 minutes to do it right.
It was deflated…and I could not easily pry it off of there. But I’ll recheck it again to see what i’m dealing with. I know the glue as sticking to the wheel and tire as I was trying to pry it off. Like I said…the main reason was because I don’t want to do damage. But I can always rip this one off there and redo it. Shouldn’t be a big deal.
The course is the IM MOO course. there are some technical areas…but nothing bad.
So unstretched, was it unglued too? The glue is pressure activated so it makes sense that it seems solid but it’s not. It will also screw up your rolling resistance if you don’t glue it properly. You should know that by now with all the posts. Just take it off and put the 2 layers on the tire 12-24 hours each to dry, if needed and a layer on the rim when your ready to stick the tire. If your worried about getting messy hands putting the tire on just wait an hour before you put the tire on to let the glue dry a little.
