TT cockpit upgrade question – Canyon Speedmax SLX / 20° extensions
I’m currently riding a Canyon Speedmax SLX with the stock Canyon front end (Upgrade Kit).
This summer I’m racing Challenge Roth, so the focus is clearly on long-course position sustainability rather than short TT efforts.
I recently completed a professional bike fit. One of the key outcomes was a recommendation to move to 20° extension tilt (high-hands style) to reduce neck/shoulder load and improve positional stability over 4–5+ hours.
Pad width is set at 22 cm (c-c) and works very well for me. Drop is moderate, position is already dialed in — I’m not searching for a new position, just trying to execute it optimally.
Now I’m evaluating the front-end options:
  1. Keep the stock Canyon cockpit and use Canyon 20° spacers
  2. Keep the Canyon cockpit but use RadSport 20° angled spacers
  3. Upgrade to a Delta Speed front end
  4. Upgrade to a Fast TT front end (excellent, but very expensive)
Main questions for those with real-world experience:
  • Can the stock Canyon cockpit, with angled spacers only, realistically deliver a stable and comfortable 20° setup for 180 km?
  • Does something like Delta Speed provide a meaningful improvement in comfort, stability, and fatigue reduction for long-course triathlon — or is the gain mostly marginal if pad width/reach are already correct?
  • Any downsides you experienced with higher extension angles on the Canyon system (wrist angle, elbow pressure, torsional stiffness)?
I’m trying to understand whether this is a case where small, smart modifications are enough — or if a more integrated front end is justified for Ironman-distance racing.
Appreciate any technical insights, especially from riders who’ve tested both stock Canyon setups and aftermarket cockpits over long distances.
If your race is in June I will have a tilt base and wing well before then. My new full arm just opened large molds riding samples so. With a spring targeted release. All together under 950 usd. Something to consider. I’ll be reading the rising sample in February.
What year is your speedmax as the current model cf slx can’t be put in an armpad width of 22 cm c-c measured?
And as cyclenutz says below, safest option is the Canyon 20 degree kit. I have built several bikes with that kit and everything is solid quality.
Jeroen
That would be the safest option - the kit has been properly tested together.
Deltaspeed the injected carbon raises questions and there is no mention of independent testing on their site.
Hi. My Speedmax SLX is 2022.
