sorry in advance if this has been answered a million time. If you had two bikes that fit correctly with similar geometry and one was a typical entry level aluminum $1500 bike and the other was a high end TT bike with the rear wheel smooshed into the seat tube, the fancier aero bars, stuff like that.
take out the whole rider position, wheels, crash hat, all that.
How much of a difference does stuff like frame shape and components make for a 27 mph sort of rider, assuming the same position going down the road?
Unless the 1500 bike is a p1, in which case ~ .5 - .75% faster
If your FTP is 250 watts, that is 5 watts @ 30mph, but you don’t ride that fast, so call it 2-3 watts @ 24mph.
2-3 watts is usually considered to be 10 seconds in a 40k.
Lots of people who read marketing hype will say I’m wrong. None of them will post numbers proving their theory.
The extra $$$ will get you carbon over alu, a lighter bike, and better components. Oh, and the bling factor tri geeks are so in love with.
Can’t beat a p1 (long and low) or equinox 7 (short and tall) in the bang for the buck category. Spend the rest on a coach, a powermeter, an aero front wheel, and a disk cover.
You haven’t given numbers supporting your theory. And there have been numbers from well conducted experiments posted on this forum that indicate you are a long way off in your suppositions, Mr Search is your friend.
Though I agree that expensive bikes are not necessarily the best return on investment when you’re looking for speed/$
I’m curious, have you not seen posts by Tom A. on this subject?
how is that possible?
2% faster @ 30mph
Apparently I’ve not seen his posts. Anybody have a link handy?
But I did go re-check my sources, and, gasp!, I screwed up.
The difference in a Tarmac and a Transition is 7.8%. The difference in a Madone and a TTX is, shockingly, 7.8%, both @ 25mph. (Okay, so one was at 40kph…)
So, new numbers: given an FTP of 250, you are looking at…19.5 watts difference. Or given the 2-3watts ~ 10 seconds ROT, 60-100 seconds over 40k.
Arguably that is going from 2 very un-aero bikes to 2 very aero bikes, so YMMV.
Going from a road frame to a highly aero frame is typically a savings of 45sec.-1min. (again HIGHLY dependent on what two frames are being compared). Aerobars are all about getting the rider in the right position. Bigger savings than frames are aero wheels and an aero helmet. Get these before spending on a frame…and an added plus is that they can follow you to an upgraded frame later.
does the more expensive frame tend to allow for more drop to the bars? I’m hardly agile, but it seems like the limiting factor on some of the frames is the ability to get the bars low enough.
Very interesting. We here a lot about this bike being the fastest, better then that bike by 50 grams of drag, fast then last years model etc etc…
It is difficult to convert that into real world saving. Often the biggest saving of drag at a given yaw is used. For example the cervelo graphs getting around this forum show that the bigger the yaw the close the P3 is to the P4.
Obviously from a road to a tri/TT bike will be biggest savings…
My BIG QUESTION is though - just how much difference in seconds over a 40km TT averaging around 40km/h are there between the big name frames such as P4, Shiv, TTX etc…
2nd Question - how much do those frames save over something like the P1/P2 or Transition…
tom a. here has done field testing comparing the P1 to the P3C
search
Each frame is different. It’s fair to say that cheap frames usually have a shallow drop, but expensive ones run the gamut. The stack & reach data (link on the ST header bar at the top of this page) will let you know how each frame fits. Also consider the ability to adjust the height of the pads relative to the base bar. Some aerobars have very little rise (Valdera), while some have lots (Syntace), and some are adjustable with spacer kits (HED). Drop can also be created by a downward sloping stem (or Look Ergostem).
All of this is a case for getting fit first, then selecting a frame.
Oh, thanks I always wondered what that table did–looks like the big number take away the little gives your the drop to the bars, which in my size seems like 4 inches. I’ll have to study up some more.
Stack is the height from the bottom bracket up to where the stem connects. Reach is the horz. distance from the bottom bracket to where the stem connects.
The idea is that there is a lot of adjustablility to move the saddle up/down and fore/aft, but Stack & Reach tell you how long and low the frame is (the smaller the Stack, the lower the bars will be). A frame with a 1cm smaller stack will allow the bars to be 1cm lower; this is independent of saddle height.
