TSA & Hutchinson FastAir
Will TSA jack my FastAir?
If they find it and know what it is yes. Don’t get on a plane with a banned item.
Styrrell
Thanks for the advice. What’s the chance of finding some at the IMC expo or local bike shop? Any idea?
Not a clue, someone may chime in. When is the race? If you have enough time you could send the stuff to your hotel through the mail. Or order from a MO and have sent directly.
Styrrell
Good idea, too much on the mind right now. Should be able to have some shipped in time.
Thanks!
Find out if a nearby LBS stocks them, or better yet, if the sponsoring bike shop stocks them.
You may be able to return it if not used, because if you don’t use your Fast 'Air or Pitstop, you can’t bring back with you in the plane.
I try to return and get store credit and buy something from the bike shop that you can bring home :slight_smile: Usually ends up to be inner tubes or GU’s
Good idea. I just emailed Bike Barn to see if they carry it, if not, maybe they can get some for me. Thanks!
Anything that has compressed air in it is prohibited, unless it’s empty and the ‘valve’ is removed. Which sort of defeats the purpose.
