I just built up my bike with DA 10 and went for a ride. The left crank arm fell off while I was riding. Has this happend to anyone else, and what did you do?
Thanks
Thanks
I haven’t seen that happen before. Did you tighten both of the pinch bolt up to the correct torque spec (12-15 Nm) after you screwed on the end cap? Check your assembly to make sure everything went together correctly.
I have seen that a few times…each time with folks who did not use a torque wrench and READ the directions. Get a torque wrench man. Shitty design yes, but still - get a torque wrench.
