The weather let up enough here today to take my tri bike on its maiden voyage. She is a rocket with a tubular trispoke in the front and Hed disc in the rear. I love this combo!
My question is, I have a Polar cyclometer w cadence I want to set up and wondered what the best option is for mounting the sensor to the trispoke. I have the sensor that came with the Polar attached to another wheel set that I’ll also be using with the bike. Does someone offer a magnet that I can glue on the wheel or is there another option out there?
Also, I have Easton Attack bars which don’t offer a good spot for mounting the display. I currently have the display mounted on stem but this is all but impossible to see in an aero position. Any suggestions for placing my Polar cyclometer on Attack bars?
I’m sure this has been discussed numerous time on ST but my half-assed search turned up nothing.
You can use another Polar magnet (or any other brand for that matter) and attach it with a dab of chaulking. If you ever want to take the magnet off, it comes off without much trouble, and it’s easy to get the caulking off too.
We get high stength magnets from Radio Shack. They are very small (~5mm diameter) are can be affixed to the wheel via a light adhesive. They cost about $5 for a pack of 10.
They are neodymium magnets–so-called ‘rare earth magnets.’ Radio Shack.
You can mount them on the surface of the spoke or rim, OR you can mount the magnet inside the stem cut out–if it’s in the right location for your sensor.
For the speed sensor find some rare earth magnets and glue it/them to the rounded portion of the valve cutout. I tried the Radio Shack magnets, but couldn’t get my sensor to pick up. I found some at a craft store that were about the size of a button but since they are mounted inside the cutout so I have to move my sensor pretty far inward to get consistent readings. The Radio Shack magnets are really, really small. The only problem I’ve had with this is when I switch wheels I have to adjust the sensor out slightly.
We used a really simple solution. I had some old Cateye magnets - big plastic ones that screwed between the spokes. I opened one up, took out the magnet and stuck it on with electical tape. Yes, it looks cheap, but it’s still there after three seasons.
