Can anyone direct me to an Omega diagram, or feed me a couple measurements? I’m trying to determine if the Omega will fit inside my bike’s nosecone. Needed is the maximum side to side width of the body about where the cover screws are, and the center to center screw measurement at the cover screws. Also needed is the front to back maximum depth from the mounting hole to the leading bulge of the cover.
Perhaps an email to Nick from Tririg?
I tried that first but didn’t get an answer, so figured Slowtwitchers can usually find good information.
Can’t help you with the measurements, but why??
Softride customization version 2015. I have a custom nosecone/nutrition system on my Softride that houses a Shimano AX brake. The lower portion of the AX levers and the pads protrude below the nosecone. The Tririg Omega appears to have better stopping power, more adjustable pad control, and some modularity that might help me mount my nosecone and route my front brake cable more cleanly, if I can fit the Omega inside my nosecone.
