TriRig BTA Elevator
Correct and correct. :slight_smile:
And think of this scenario…you leave T1 with 3x 20’s bottles, or any “legal” combination under the 2L limit. You replace a smaller bottle with a larger one at the first aid station putting you over the 2L limit. Is an on-course ref going to issue a penalty? Couldn’t you just drop a bottle at a trash station before entering T2?
I get the reason behind the rule is safety, and not having a ton of weight connected to the steering axis of your bike, but again enforcing these rules leaves a lot of gray area.
The is no optimal. Sorry
from already having tested 3 people this year, we ended up with 3 different bottle placements that were optimal
Want one…
Anyone ordered from TriRig to Europe? Trying to understand if the prices are inclusive of taxes / duty as the website is a bit conflicting in info.
Are you sure you want to buy one with the new hydration rules ?
Ordered full cups in France last October, received later an 85€ VAT invoice :frowning:
Height is adjustable so it’s easy to make compliant.
I wish they made the elevator start out at a lower height
Even at its lowest level it is too high for me
Maybe I don’t have it installed correctly?
I’ll try changing a few things and see gown it goes
If you like we offer a cheaper option, similar design, 129 euro for elevator and rail.
If you interested send a PM
Sorry for the bad pic :-). But you get the idea, works like a charm.
Jeroen
What is the minimum stack height on this?
15 cm but you can very easy cut the insert to create a lower stack if you are above the 20 cm limit rule
Jeroen
