I am not sure which of the two (even three) Triall3 cases I should buy. The way I see it is that “Compact” is probably the best being the smallest and the lightest at the expense that you have to detach the pedals and the handlebars (which should not be a problem). Also, somewhat less room for other staff in the case – this, in fact could be the biggest plus for the Pro - Custom. If for that reason you opt for the Pro, then the next question is why not Pro II. Again, at the expense of some pedal and handlebar dismantling you can now take your friend/spouse bike with you as well. I am probably missing something and I would appreciate any input.
Thanks!
I have the custom road which is a bomb proof case and very easy to wheel around airports etc. The only down side is that it will not fit in a car trunk. In fact with the top on it won’t fit in the back of many suvs standing up. When I travel I usually go with a minivan. One other thing to watch with the large case is that you will run into the weight limit pretty quick. I’m not sure if it’s cheaper to have one overweight case or two smaller ones. It is a great case though. I have a big bike and am able to put almost all of my race gear in one package.
I have the Triall3 Pro - but mostly because I got an awesome deal on it on ebay.
But I have grown to like it - found I can fit 3 wheels inside along with a lot of stuff. And I like that I don’t have to take the pedals off - just the seat - and I can turn the handlebars and leave the aero bars on. Very easy for me.
I have been able to fit in most SUVs and minivans - sometimes have had to put it on its side.
It is easy to wheel around the airport. And very sturdy.
I live about 2 miles from TriAll3 and I went in there with my Cervelo Dual 51 and they recommended the Custom Road. I’ve taken it on two trips so far…actually one I shipped it via UPS and the other I took with me on a Continental Airlines trip across country. I had to remove the pedals, saddle, and wheels and simple turn the bars down, but not remove them. With the new UPS shipping rates, it will be EXPENSIVE to ship one of these cases, so from now on, I’ll have to resort to taking it with me unless I’m going somewhere relatively close.
I have ample room for everything in the box with my bike: wetsuit, helmet, pump, shoes, etc.
Thanks to all who replied thus far. It would be great to hear from someone who has the COMPACT.
P.
IMO the custom is the best option for a single bike. It requirest the least amount of break down of the bike. Other than the clam shells it’s pretty much the same dimension as the other velo cases.
