Tri suit suggestion about wrinkles?
I’ve been using a LOUIS Garnau back zip suit for a few years. I am not sure it is even a tri or not. Has almost zero wrinkles when in aero position on bike
It’s getting stretched out. They don’t make it anymore and
Am looking for a front zip suit to hopefully be a little cooler when partially unzipped I’ve tried the new LG tri suit as well as two of the ROKA tri suits All have a lot of wrinkles on me when in the aero position
Even tried larger and smaller suits .
Any suggestions to either get rid of the wrinkles?
Of what suit others have found to be wrinkle free, understanding each person is different.
it all depends on the person, the quality of the shoulder shrug, and the cut of the suit. It’s individual.
That said, the two that I like are Scody and Kiwami. Stretchy material in the shoulders that conforms to the rider and cut properly so that it doesn’t bunch up.
Eric
Eric
Thank you Eric!!
Any particular model(s) of those brands you like more than others?
Last question. Do you believe white is cooler than cool black?
I don’t know about white vs. black other than the obvious.
For Scody any Optimize AIR suit with sleeves and for Kiwami the latest LD Spider 2
Eric
Eric
Thank you Eric!!
I find that anything that doesn’t crumple around the armpit, is too tight for running in.
Fortunately I have not had that issue
