Tri shoe for pronator
Looking for a Tri shoe. I’ve got a wide foot, bow-legs, and no almost no arch. I’ve been using the Shimano tri shoe with my orthotics in, but the right knee is still taking a dip towards the top tube and screws up the pedal stroke, especially when I’m applying a lot of force (left leg’s fine). Anyone know of a supported shoe, or any method to raise the inside of the shoe to get rid of the knee-thingy (if I could fix the problem and still use the shimanos that’s be awesome—they’re a great shoe).
Foot pronation only has a small effect on total knee movement when cycling. You might want to try some external varus based wedges under your cleat to help your knee track straight up/down. Google LeWedges (formerly Big Meat or Lemond wedges).
Good Luck!
Hi
Check out Specialized’s tri-shoe. It has a very noticeable outward tip to it’s construction.
They describe it as 2 degrees Varus. I love my knees brushing the top tube so they did not work for me…but for you they could be the ticket.
i agree with rroof. also the specialized shoes have some varus built in which is nice. If you are really overpronating a tri shoe may not be for you. I ride specialized road shoes because they hold my foot more stable by wraping over the top.
Dan
www.aiatriathlon.com
Thanks all for the help, I’ve looked at the LeWedges and the info on the website addresses my problem perfectly.
I bought some orthotics from esoles.com. (you go to a fitting center) BUT, you can get a private bike fit from Bill Peterson. He’ll figure out the answers for you. I highly reccomend looking into this.
