In the market for a tri bag. What do you have? What are the goods and others of it?
I use a large Speedo swim bag , suits my needs.
I use the TYR transition backpack. Its great. Mesh pockets inside for everything, a plastic clip in bag for wet, stinky stuff, pocket on bottom for towel or wetsuit. You can clip your helmet on the front under the bungee (but ake it off for over head bin on plane). About $50. Very happy with mine…kj
Just use a backpack unless you want to spend the extra $.
I recently got the DeSoto transition pack, and I used it at a race for the first time last weekend. It’s great! I used to use a regular backpack, but this is SO much bigger. It’s cavernous, has all the right compartments (including a wetsuit compartment on the bottom), and it’s also a backpack! I like it.
-C
I’ll second the DeSoto bag recomendation. It has all the little pockets and compartments for all your tri stuff, and it wears like a backpak. It’s also a hell of a great triathlon business to support…
I have the desoto also, although a friend of mine has a saucony he got when he joined USAT . I like the way his unfolds and is easily organized.
but I haven’t used it. I can say the desoto works and works well. it’s comfortable to wear as a backback riding to the race, the wetsuit compartment is perfect, and everything fits just right. not too big , not too small…
I have the bag from Blackwell Research. It has more pockets than I know what to do with and a removable internal wetsuit bag. Great construction, all of the available bells and whistles… (Dave, if you are listening, you need to start sponsoring me with as much good press as I give you!)
Seriously though, it really is a great bag… check it out- www.blackwellresearch.com
