Trek TTX aerobar height help please
I’m hoping one of you kind folks can help me out with a measurement on the 2007 Trek TTX 9.8 or 9.5 in ‘Large’. We are finalising bike choice for one of our shop team riders and are concerned that we may not be able to get a low enough position without resorting to strange stems and other jiggery-pokery. Yep, no spacers here you’ll be glad to hear. While we can make a good guess with the measurements supplied by Trek, we can’t get our hands on a built bike to take an accurate measurement. This guy knows what setup he needs to go fast and those last few mm are important (I can also work with inches).
I’m looking for the measurement from the top of the headset to the floor (with a wheel in!) - i.e. the lowest possible height you could mount the stem.
Thanks in advance for the help.
Sorry mine is a medium (56), but let me know if that would help.
PM a poster named “cyclenutz”
He has every measurement you could ever need for almost any bike.
I use the older TTT and have a profile design -25d 130cm stem…
dunno about ttx.
g
I can’t help yu with the measurement, but what do you consider to be “strange” stems? Deda makes the Newton in a downward sloping Pista version that would be good for tweaking a position by a cm or so.
I’ve got a listing for the stack height (vertical ditance from height of bb to top of head tube) being 56.8cm on the Lg. Thank Dan for that number. What kind of bars is he planning on using?
Wow, that was quick - thanks all. The ‘stack height’ should do nicely - thanks Mr Santos.
I hope I haven’t caused offence to any users of ‘strange’ stems by the way, it’s just more convenient to use stock road stems if possible.
It’s a pretty standard setup, stock bullhorns with Profile T2 that he used last year to great effect.
If the front end height is still off by a couple of centimeters, don’t despair. Going from a T2 to a lower stack aero bar will drop the front end by another 3-4 cm. For an S-bend similar to the T2 but lower, I really like the HED clip on’s. You can easily modify those bars so the flip up feature is disabled. Good luck.
I think the 568 is the vertical height of the top of the seat tube above the BB (=585 x sin(76))
I get the stack of the top of the HT to be 551.
S: 504
M: 514
L: 551
XL: 579
If we assume a wheel diameter of 334 (700x23 tyre) then the medium should be 848 to the top of the HT (within a few mm allowing for rounding errors and production variance). If you measure the M and find this is incorrect it matters little - the HT on the large is 37mm taller vertically than on the medium and you can use that figure regardless of the accuracy of my other calcs.
I knew you’d have the asnwer :slight_smile:
Again, thanks very much. I’ll get my maths head on when I get back in to work on Monday and go through some options.
