Trek Speed Concept 9.9 bolt replacments
Does anyone know where a person could get new bolts for a Speed Concept, after a couple years they are starting to get rusty. Most importantly I need to replace the steering axle nut. I have emailed Trek but received no response, same goes for my local shop. Any information would be greatly appreciated.
Thanks,
mcmaster.com
You can get anything you’re looking for there as long as you know the length and thread size you need.
I replaced everything up front with stainless from MrMetric.com but I would imagine the steerer nut would need to come from Trek. Any Trek dealer should be able to order it for you if they aren’t too lazy to look it up in the system.
I just ordered the replacement cap screws and wedge bolt from Trek dealer, plus bearings etc . . …
stem cover bolts (and bar to stem bolts) come in a kit: w308017
rear brake cover bolts are W311088 (x2) for the pair of flanged-head bolts and W311089 for the longer button head bolt…only the former should need attention, as the latter was spec’d stainless from day one.
the bolt kit for the bars is 420693 (x2)
the preload nut (threads on to the internal steerer and is clamped by the stem) is w328492
The bolts the hold my brake pads in place have stripped. What’s the code to order another set?
