Treadmill transfer to the road?
the foot pod is a good idea. i’m particularly curious about elevation gain. so, i brought in my gps unit in order to calibrate the accuracy of the treadmill at the gym.
wouldn’t you know it? no signal. :frowning:
I agree, it sounds like it. But this is where is gets complicated. It sounds like MagnaDrive is a control unit that is embedded in that particular treadmill. So it depends on how the treadmill designers hooked up the control unit. Did they actually make a sensor to measure belt speed, and provide that as feedback? If so, then the speed will likely be accurate. They might have taken a short cut, and just measured motor speed. The motor may then connect via one or more belts to drive the actual running belt. The running belts stretch over time, and all treadmills provide a means to tension the belt. So in that system, all the errors between the motor and the actual running belt are not accounted for.
I would just e-mail the company. Tell them you are investigating a treadmill purchase, but need precise and accurate speed control. Ask them to provide a speed accuracy specification. If they can, then you will know the maximum error. If they cannot, then you know the unit does not have closed loop control, or that the control is of something like motor speed and not acutual belt speed.
Paul
I’ve tried it with my Polar 625, and it didn’t work.
It should work fine if you just bring your treadmill outside…
:wink:
Jodi
I don’t know anything about GPS units but altitude on the 625x works off the barometer function in the watch and not the pod (i.e., you actually have to change altitude).
Texas has gone from Spring to Summer in about 72 hours and I swam first and it was hot when I got out on the run. At around mile 6 I detoured into Lifetime Fitness to run 3 on the treadmill before I passed out before the final mile home. Was on the Lifetime Fitness treadmill that is gray and silver. The Polar 625x was the control (right or wrong). This treadmill was about 15 seconds fast on the pace and the pace varied when it shouldn’t have. I don’t think it is a closed loop feedback system that Mr. Dunn described.
On every treadmill I’ve been on my RPE goes way up at a given pace relative to the road. I absolutely hate treadmill running.
I’ve talked with others who felt it was faster.
Thanks - only problem is that Life fitness seems to have several models, only some of which have the magnadrive speed control (which may or may not be a closed loop system). It’s possible you were on one of the ones without magnadrive. Also, not too sure about using the polar foot pod as a control - it would depend on calibration, etc. Thanks for the data though!
There was a similar discussion of this issue a few months ago. The comments in the article are based on some misleading assumptions.
It is important to recognize that all motion is relative, and the movement of anonject can only be dfined relative to that of another.
When you run on the road, the propulsive force works against two main forces: friction and wind resistance. Wind resisttance is minimal at most training speeds. Friction will be a function of weight, speed and the coeficient of friction.
On the treadmill, the friction may be slightly different than on the road, but probably not a whole lot different. There is no wind resistance, but that’s of minimal significance at low speeds.
So you probably need to run the treadmill just slightly faster to simulate real road running, but not a whole lot faster. There was a chart I saw somwhare before. If I find it, I’ll post it.
Here it is
http://www.anglebar.com/chaneyfamilydotcom/runwithed/treadmill.html
I’ve read that the additional heat stress of the treadmill (due to being stationary) makes up for the additional energy demand of wind resistance on the road, so in the end there’s no need to run faster or use incline to compensate. Personally I find I’m slower on the trainer than the track, but my power output is also significantly lower on the trainer compared to outside. I don’t think I’m particularly good at coping with heat stress!
I"m a 100% treadmill junkie. Have trained for several marathons and two IM’s by ONLY doing treadmill running. Yep, even those 22 milers on Sat. morning.
I ALWAYS run faster on the road after treadmill running. The road is only for races though. I do find that it’s a slight adjustment from treadmill to road (can feel it in my hips a bit) but after about 4-5 miles-in cruise control.
I have much fewer issues/injuries this way and no, my recovery after a race is not much different from running on the road/vs treadmill.
Christine Clark won the 2000 Women’s Olympic Trials Marathon after doing most of her training on a treadmill. Clark was from Alaska so weather and a lack of daylight didn’t let her train outdoors for much of the year.
I do a lot of training on the treadmill, too, and have found it a good tool especially on recovery days when I can force myself to run slow. Speed definitely varies from treadmill to treadmill especially at health clubs where they get a lot of wear and tear. Better to go with HR than the pace displayed by the machine.
