Can anyone recommend an app to transfer songs from an Ipod to an ITunes library? I’m looking for something like Senuti, but for PCs.
Can’t you just drag and drop? The iPod is likely to be treated as just another drive on the computer, just don’t let it launch iTunes. Then open it, open the local iTunes folder and drag and drop the files.
I used an app called iPodRip when I needed to recover my music from my Touch to a new machine after a crash. It worked great. The only issue is that the demo version is limited to 100 songs. After that, it blocks you out. You can get around it by creating a Restore Point in Vista right before you use the App, and then restoring the PC each time. Not bad if you have < 1000 songs, kinda a pain if you have 15,000+… I suppose you could always buy the full version… ![]()
Unfortunately no. If ITunes sees an IPod it does not recognize, it will not let you import songs from it. You can download songs to it, but it wipes it clean before that occurs.
I have not tried dragging songs onto the desktop, then dragging into ITunes, but I can’t imagine Apple would let this occur. They block moving songs from Ipod to Itunes since you could in effect use your Ipod to collect the libraries of all your friends then transfer all the songs into your own library.
I have copied songs from my ipod into a folder on my hard drive. Then used Itunes to add a file or folder. The only issues I have had are sometimes the files are not renamed in tunes correctly they come up with something like ADFZ
Yeah, I’ve done the same thing with dragging songs onto the desktop then importing them. I don’t have iTunes on this computer but I do at home. I can take a look when I get home. I know I back up my entire music collected onto an external hard drive.
You need to enable “show hidden files and folders” for the iPod on your PC. Then you’ll be able to get to the music files and copy them to your hard drive.
The process:
- go in to ‘My Computer’
- enable hidden files under Tools->Folder Options…->View, and check Show Hidden Files and Folders
- without iTunes open navigate to the iPod and find the folder that has folders in it named ADFW, ADFWE, etc. (don’t have an iPod with me so don’t know the name of the folder, it’s NOT the Music folder). These folders contain the music files with ‘secure’ names
- copy and paste all those folders to a single directory on your hard drive.
- open iTunes and set it to ‘Copy Files to iTunes folder when adding to Library’. You might have to allow it to ‘Keep iTunes Music Folder Organized’, but be aware that this will screw up your library is set up in a manner other than the default.
- add the entire folder that came from the iPod
- as iTunes adds the files it will rename and reorganize the files into the correct albums structure.
- you can’t do this with a Touch.
You need free hard drive space at least double the total size of the music that’s on the iPod.
Hope that helps.
http://download.cnet.com/iDump/3000-2169_4-10702731.html
This does it, it worked for me
