I would have to disagree. Training the time-constrained age-grouper is one of the easiest tasks there is for a coach because sucess is always a given. That’s why you see so many “good” coaches around.
“because sucess is always a given”
Do you mean that people always improve with any sort of program? I see that, too.
But, what I mean is the serious, competitive time-constrained athlete. While a consistent, general approach can lead to good races, if a coach devises a way to push that athlete to the brink, but not over it, with the right mix of intensities, the 10-hour athlete can become an AG leader.
I am intrigued with the concept of the maximal total training load and adaptation that is possible on limited time. More time is almost always better, but how far and how hard can we push a 10-hour week and still get better? It is riskier than a high-volume approach. Injury and burnout are always one stupid workout away.
But, I want to do it anyway since I don’t have 25 hours/week to do it the safe and sure way. Frankly, I get a charge out of the idea of training harder than all the USAT-certified coaches say to do it. It’s part of the rush I get from the sport.
Julian,
Talent is a factor that affects results at every level of competition, even age-group. The talented age-grouper would still be competitive on less training than the not-so-talented with more training.
I see people here doing training volumes that completly amaze me. Now why aren’t those people top-10 overall material? Because it’s not the training volume or intensity or the interplay of both that affects results. It’s talent, always talent ![]()
Hi Julian,
thanks. That’s all nice and good but doesn’t really answer my question.Here is my question again. Why can some people, when compared to others, consume a greater percentage of their VO2max when racing?
Your answer: “Genetics and training”
But what kind of training. How should a guy that can sustain 70% of his VO2max train differently than the guy that can sustain 90% of his max Oxygen consumption. Of course you can look at it in terms of Power. But Power is Work over Time. And in order to do work you need energy. In order to make ATP you need oxygen (at least in aerobic events such as triathlon). I understand that the max Power sustainable translates into performance. But I rather use the term of Oxygen than Power in this case since it eliminates biomechanical efficiency. Efficiency is very important, but I want to look at the scenario from a physiological perspective. So back to my question, why? Can we wisely use this data to maximize performance or should we simply train according to the involved energy systems?
I think trying to over analyze lab test results can make things seem more complicated then needed.
If your goal is to improve your power at LT, then training at or near your LT (both over and under) will increase the percentage of your V02 max you can sustain. Workouts like 4x15mins or 2x 20 mins at LT +5%, or 1 x 60 mins at LT -5%, regular club type time trials of 15k and 40k, etc all will help.
For the example you provided: “How should a guy that can sustain 70% of his VO2max train differently than the guy that can sustain 90% of his max Oxygen consumption”. More information is needed to fully answer the question, such as race results (splits) from actual races (sometimes doesn’t line up completely with lab test results), training history (how has the athlete trained in the past, focuses, volumes, intensities), and short and long term goals.
BUT given the hypothetical senario of the 70% guy - just train more at LT to improve it. For the 90% guy - do some work to try to raise V02max (raise the ceiling) and then look to improve the other performance factors such as efficiency, nutrition, mental prep, etc as most athletes aren’t able to increase their LT too much more than 90% of Vo2 max.
Joel
BTW - having seen a lot of power data over the last few years, I’d say your power at LT is very solid and you’ll do quite well on the bike in tris with appropriate trianing. Certainly solid enough to be competitive in the elite catagories at least on the bike.
How are your swimming and running?
Joel
…have a terrific training approach for the high-volume athlete looking to break through to the top of their category. But, like you say, a high-volume program is pretty simple: big miles at solid, steady paces.
I agree, BUT i think eventually an athlete can tap out the gains from this approach.
This is from another post I wrote over there in a different topic:
"I believe that the steady work is fundatmental to IM success, but if an athlete always does the same training at the same pace, then over time they will get less and less adaptation - change in pace and duration, but also focusing on different areas as indicated by the program and race results (threshold, V02 max, endurance, aerobic power, etc) depending on the goal of each training phase is neccessary to continue improving. So many athletes get stuck at a certain level, partly because they continue to train the same year after year. Remember the definition of instanity quote “doing the same thing over and over and expecting different results”.
Joel
“But what kind of training. … Can we wisely use this data to maximize performance or should we simply train according to the involved energy systems?”
I’d go a step further and say that we don’t train according to energy systems. It’s a myth that these systems turn “on and off” at different intensities. They’re all operating all the time. But, it is very important to understand that, at race pace in endurance events (ie, longer than about 2 minutes) the aerobic system is the only thing that matters. Once you’re traveling along at more than a few tens of minutes, the aerobic system is providing danged near 100% of your energy.
And, I just don’t see anything useful in knowing that, right now, my LT is achieved at X% of VO2max. I mean useful in the sense that I would alter my training. If X% is too low, I’ve just got to keep training – and training the aerobic energy system.
Now – as for the question: What kind of training? Well, that’s a whole nuther debate. Some say long steady; some say short and intense. Advice is all over the map, and people get better doing all sorts of things. A few things everybody agrees on: Consistency. Patience. Volume. Years. Recovery. Nutrition.
I personally think threshold hard-tempo efforts are the cornerstone of increasing power/pace at LT. Longer endurance efforts help get ready for those, and are crucial for getting ready for long-course racing.
But – if I understand your question right – I don’t think there is anything in the data arising from a VO2max or LT test that would cause me to alter my training regimen. If I’m not where I want to be, I’ve gotta just get out there and hit it some more.
Hey – you’re singing my song. I spent a year running steady long miles, and capped it off with a personal worst in the half marathon.
BUT – when I hit the hard tempo stuff again, I got faster fast. Within two months I was setting PRs again.
"I think trying to over analyze lab test results can make things seem more complicated then needed.
If your goal is to improve your …etc."
Excellent summary. Better said than I said it.
thanks joel,
finally an answer to the training approach question. I was thinking the same and completely agree. Instead of only focusing on training the energy systems the athlete uses during competition, e.g Ironman, the athlete should use those lab data and also train specifically to improve his limitations.
Anybody aware of any scientific research on training to improve LT vs. training to improve VO2max? Looking at Coyle, Coggan, et. al study (Determinants of endurance in well-trained cyclists), it seems that a higher percentage of type I fibers and greater capillary density are the variables that separate the high from the low LT (as % of VO2max) cyclists. So the question that arises: how do you increase capillary density? Is it the long steady submax efforts or the high intensity workouts?
You wrote that the guy with the low VO at LT should train at a greater intensity. You have much success coaching and I therefore take your word for it. I also speculated that this would be the case. So let’s take it a step further. If such a training protocol would be successfull we could make the assumption that high intensity training causes adaptations to those two morpholocial changes that separate the “high VO at LT-group” from the “low VO at LT-group”. Is this true? Is there scientific evidence states that the high-intensity training is responsible for increases in capillary density and/or the shift of muscle fibres toward type I? The greater intensity should cause the athlete to work with more power, therefore recruiting more type II fibres. This pretty much rules out that high intensity training causes a shift toward type I fibres. High intensity training could still expand the capillary network. And then of course we shouldn’t ignore the possibility that those “high VO at LT athletes” have choosen their parents well.
thanks joel. all interesting research articles welcomed.
daniel
"…how do you increase capillary density? Is it the long steady submax efforts or the high intensity workouts? "
See:
http://mywebpage.netscape.com/rechung/wattage/coggan.pdf
especially Table 2 toward the end. It’s the hard stuff (Levels 4 and 5) that give the best bang-for-the-buck.
Short, intense intervals (4-5 minutes) are best for maxing out that last bit of VO2max. It doesn’t last though, since you shouldn’t being doing that kind of work year-round. I like the idea of saving it as final prep and peak for an A race.
hi julian,
Re: “I’d go a step further and say that we don’t train according to energy systems”
First, why wouldn’t you want to train your energy system that you mostly use? Did you ever see a successful Ironman athlete just doing 100s repeates on the track? Or a sprinter that runs 120miles a week. I think that all successfull athletes, that perform close too their potential, train according to required energy systems. Wouldn’t you want to increase your aerobic enzymes, mitochondrial density, etc. to be more efficient in the energy production pathways that provide “danged 100% of your energy” during an IM?
Re: “It’s a myth that these systems turn “on and off” at different intensities. They’re all operating all the time.”
I agree, but like you said, in most cases there’s one that predominates.
Re: “I personally think threshold hard-tempo efforts are the cornerstone of increasing power/pace at LT”
Totally agree. But aren’t you also stimulating that specific energy system while doing so?
Re: “And, I just don’t see anything useful in knowing that, right now, my LT is achieved at X% of VO2max. I mean useful in the sense that I would alter my training. If X% is too low, I’ve just got to keep training – and training the aerobic energy system.”
So if you already maximized the amount of O2 you can consume during a sustained effort. Would you still try to improve that variable? Personally, I think it’s helpful to have feedback on what you have to work on.
Re: “I don’t think there is anything in the data arising from a VO2max or LT test that would cause me to alter my training regimen. If I’m not where I want to be, I’ve gotta just get out there and hit it some more.”
Well, if you are not where you want to be you just go out and hit it some more. I’m not saying that you have to sit around at home, waiting for some hot princess to fly buy and deliver a package with extra VO for “at max” and/or for “at LT”. Of course you have to go out and train. The question is how you should train to maximize your performance.
peace,
daniel
julian, thanks for the link. Don’t have time to read everything right now. But I looked at the tables. Seems like great reading and answers some of my questions.
thanks,
d
"First, why wouldn’t you want to train your energy system that you mostly use? Did you ever see a successful Ironman athlete just doing 100s repeates on the track? Or a sprinter that runs 120miles a week. I think that all successfull athletes, that perform close too their potential, train according to required energy systems. "
Well, yes of course my workouts are chosen to enhance the relevant system. It’s just that it is always the same system, every day, every week, every year. So, for all practical purposes, I can just forget about the system involved and just do my aerobic workouts. Those workouts range from easy to very, very hard. But, they are all aerobic.
I never work on anaerobic power because I will never use it in a race. My shortest, hardest efforts are 4-5 minutes.
I was sort of trying to make the point that these systems are really quite simple. There are myths floated by people like Mark Allen that there is a “fat burning zone” and a “carbo burning zone” and that “anything where you’re breathing hard is anaerobic”, etc. It’s all a bunch of urban myth and lore that is not really true.
The vast majority of triathletes are taught that “anaerobic” is “anything done at a hard pace”. They might be surprised to learn that an anaerobic effort cannot even be sustained for more than about a minute. Even a world-class 1500 meter race only involves about 20% anaerobic energy use. Anaerobic efforts are truly off the scale of intensity that triathletes need. We can train at very, very hard intensities and stay entirely aerobic.
“So if you already maximized the amount of O2 you can consume during a sustained effort. Would you still try to improve that variable?”
Well yes. But – there is no “special workout” to improve O2 usage during a sustained effort. The same aerobic training that you would normally do will take care of that. A mix of efforts over the L2-L5 range (in Coggan’s document; Daniels has corresponding paces for running). Each and every one of those workouts will enhance O2 uptake, along with everything else we need.
"The question is how you should train to maximize your performance. "
Yes, of course. And that is the great debate (beside PCs and tubulars). Whatever my personal VO or LT profile would show, I’m still sticking to my favored training system:
Frequent running; 6 days/week
One hard tempo run, one 90-minute tough hilly run, one long run. Fill in with 45-60 minute steady runs
One 2x20 flat-out bike effort on the TT course; one 2 hour L3 tempo ride with variable effort. (no time for long rides right now).
I’m only going to swim if I have a race pending. My schedule the rest of the year is only duathlons, relays and runs, so I’m not swimming.
It’s ~10 hours, and it’s built around a very high average effort level. Readers of my posts over the past year will note a transition from my focus on long steady miles all last year. That stuff got me ready for this stuff.
Theswiss,
You’re thinking too much like an exercise physiologist, start thinking more like a coach ![]()
Along the same lines with what Julian is saying:
http://www.midweekclub.com/articles/coggan.pdf
Go back and look at page 17 on Coggan’s article It’s very good at showing what “systems” develop which “characteristics”.
If you’ve got the time, long slow stuff offers some good characterisitics to some of the systems. If you don’t have the time to do the long slow stuff, you’ll serve yourself better going harder often.
