I am thinking of making the plunge into a power meter for training and racing. I actually tried the polar power product but had very bad luck with getting the unit to function properly. I am thinking of purchasing the Power Tap or the SRM product and have been leaning towards the SRM. ANyone have experience with Training w/ Power? Worth the money? Also, any advice on product (ie. SRM or Power Tap)
Lots of info on this around - both here and gordo’s site. Everything I say is purely 2nd hand info…
Power meters are the new must have toy - everyone who has one says they are great and a must-have…but people seemed to train very well before power meters…I’d only get one if I had a fair amount of disposible income…
I just bought an Ergomo but here was my thinking:
SRM - Dura-ace $3K+ too expensive but if you’re rich maybe the best option. The amateur is 2K+. Limits which cranks you use but can use any wheels. Everyone who has one - seems to like the SRM but thats true with the below also (for the most part).
Ergomo - Hard to get except campy versions - so you have to use campy cranks. You can use campy regular or compact cranks (but compacts are $$$$ and you need to use Record or Chorus I think - any wheels. Some worry about the L side only thing but my understanding is that SRM/PT/Ergomo are all about the same re: accuracy. 2005 pricing is close to 1500 - plus may need to buy cranks if you go campy and thats new for you…I’m trying some FSA square taper cranks which I heard work.
Powertap. I think the PT pro with mavic open pro rim can be had for under 900. The newer PT’s seem to have better weather proofness I hear. Hub quality isn’t the best with the pro (some say) - but I’d have gone this route as its the cheapest and sounds fairly good except for the race wheel issue. You can buy a cover and put it on but thats a pretty heavy wheel (not that weight matters much - but I’ve never fussed with a cover and already own a set of 909’s…). The SL is a better hub and even more weather-proof but more $. You can build a PT SL into a race rim and race on it - but do you want to train everyday on it? You can buy a couple different wheels - but for the $ - just get an SRM…
If I had lots of money - I’d go SRM Dura-ace. If I was poor I;d go PT pro with mavic open pro rim. If I was in the middle and had race wheels that I liked - I’d go Ergomo…
I’ve used both PT Pro and the new PT-SL. I like the SL a lot but just finished building a wheel around it so can only speak from indoor experience. The HR monitor works better on the SL and apparently it is more weather proof. I had to send the PT pro back to get the seals properly installed but once they were in it worked in everything but a full driving rain.
I like the race PT-SL race wheel idea personally - but I will also train on this wheel most of the time. If you race with a disc or have race wheels you already use then getting a PT-open pro is a better option as you won’t face as high a cost if you damage the rim. Replacing a Zipp rim can get expensive for sure.
If you have more then one bike the PT is ideal as you can switch wheels and have power information on all your bikes. The main question to ask yourself is are you going to race with the wheel - if so get a better hub and lighter / more aero rim. if not go for the PT Pro - Mavic Open Pro (or the Bontrager PT Pro from last year)
Don’t even think about the Polar gimmick. I use a PT Pro and love it. But… I’m finding myself bothered about the wheel issue. It makes any additional wheels really expensive, and limited to no less than 24 spokes. I’m thinking that I might go with an Ergomo on my TT bike as a test. If I like it, then put one on my road bike as well, and sell the PT stuff. It really would be nice to be able to use off-the-shelf wheels interchangably.
Only for campy? I just read your post and was interested so I went to www.ergomo-usa.com. There is no mention of campy, only shimano octalink. Maybe the shimano version is new?
I think not. They are not exactly a gimmick, as there is some valid information that can be derived from the units, but it’s a tool and a guide.
The basics of training, are . . . well, . . pretty basic. Train often. Be consistant. Vary the pace. Repeat. Perhaps it’s the simplicity of it all that get’s people.
My understanding is that Ergomo has made 2 crank types - octalink (shimano) and square taper (campy). They also make english and italian threaded versions.
They had an octalink recall back in the late spring I believe and I don’t think octalink has been available since.
Currently they have square taper/campy available - you can call today and buy one. I was unable to get an estimate if/when octalink would be available. It did not sound like they had plans to build ISIS versions anytime soon.
Ergomo is awesome at answering e-mails - I’ve sent them a bunch of annoying questions and usually hear back right away.
I haven’t installed mine yet - but I’ll let you all know how it goes.
Dave’s got it right on the Campy/Ergomo. I sent in my Shimano in October for the recall (in fairness, they were recalled in April and had shimano stock at that time) and waited patiently for it to be returned. I was told a couple of times that it was on it’s way from Germany, or that they would have them in 3 weeks, but those times came and went. I finally (yesterday) bit the bullet and had them send the Campy unit instead. They were supposedly getting Shimano parts in Germany a couple weeks ago, so they may have Shimano soon. With IMAZ coming up I couldn’t afford to wait any further, so I picked up a pair of campy cranks off ebay. At least the campy’s have been in use with no problems for a while.
I really like the unit itself. Being able to use race wheels or training is a big selling point. The display is nice, although it does have a few idiosynchracies. I don’t think there is any issue with measuring left side only…even if 1 side is stronger than the other (unlikely) all you really care about are relative measurements from one day to another anyway. Personally I think it is one of the best cycling investments…not only can you race and train a lot smarter, it sort of motivates you to keep your pace up or get out the door to log some miles.
i’d like to piggy back a question onto this thread re: power training. how much “work” is it to be able get the best results out of training with power? by that i mean, it doesn’t seem to do much good to have a power meter if you don’t do the research as to the benefits of power training, the methods of training, establishing cp30, cp60, etc. it’s not simply a plug and go gadget because numbers are useless without a context in which to interpret them. once you get that context, i am sure it’s pretty simple and extremely useful, but what’s involved with obtaining sufficient information such that you can really benefit from having a power meter?
Ergomo is very responsive about helping you out. I had one of the octalinks that was recalled (mine worked fine) and in August received a replacement square-taper. Since then I have not had any problems with mine.
I use powercranks full-time and have a set of Zipp 909s with which to race. After about nine months total use here are the advantages/disadvantages.
Advan
It is pretty easy to install and set up. I had no problems doing it myself.
You can ride any wheels or cranks you wish.
It has an easy to read screen with power, heart rate, speed and cadence all at a glance. The cadence can be toggled through distance, time, temp.
Disadvan
At 1300 (then) it is not cheap
If you like pretty bikes, this will not help. The computer connects with the sensor by a fairly thick wire that can be a hassle. The computer unit is also huge.
Once you ride with power, you will never quite be the same. I think racing with power in half iron or longer distances and using it as a pacing tool is probably its single greatest strength.
Go to the Cycling Peaks site and read the Power 411 and the other articles available.
Buy a powermeter, do some baseline tests to establish levels, and start generating some data. Do some power profiling once you’ve got some tests you believe are accurate.
The more data you’ve got, the more useful it becomes. I’m in my first season using mine, and it’s just starting to click in. I can sclearly see that having a few seasons’ worth of data would be very illuminating.
All in all, you’ve probably got a few hours worth of reading to get your head in the game, and then you’ve to start getting some practical experience.
I’d say it’s the best investment of time you could make in understanding the human body’s different energy systems, what type of stress provides a training stimulus for them, as well as your own strengths and weaknesses as a rider. This is even more true the less you know about exercise physiology.
Advan
Disadvan
Chad
Just how huge is the computer unit? I like the svelte PT unit. Please tell me it isn’t any larger than the notebook PC that the SRM uses…
well, I will try and answer that honestly without too much upsell (I am a coach who specializes in power based training).
I have been working with power for several years.
The basic learning curve is short and steep, but there are several good texts that can get you up the curve fast (email me and I can provide links).
As to testing, there are several methodologies, but most produce results (in my experience) that are VERY close.
The Friel method of CPxx is the most complicated and time consuming I have found. There are others that are just as accurate and are both easier to do as well as interpret.
The fastest way to learn (warning, upsell coming) would be to work with a power knowledgable coach. This way, you can learn by doing and see practical application of the principles discussed in the literature. Kinda like your high school math class, it is easier to learn by doing than by example.
If the number of spokes is your only concern I believe Bontrager is coming out with a 16 spoke version of the PT-SL. Similar to what was produced last year with the PowerTap Pro and the Bontrager Aero rim.
That’s the old wheel I had. I liked it a lot and did quite a bit of racing on it. it definately wasn’t light, but having the data after a hard race was great.
Based off the hilarious picture attached to Kraig Willet article, I would say that the Ergomo is about 1/3 larger than the SRM unit. It is really huge for a bike computer.
