Training w/ bruised ribs
A crash left weekend has left me with what I suspect are bruised ribs. I somersaulted over the handlebars 6 days ago and landed on my head/face/shoulder/back as I flipped. The majority of the impact was to my ribcage on the back right side. I can s/b/r without breaking form but there is definitely some pain. The strange thing is that the pain seems to be getting worse as the days go by. Haven’t been to a doc yet as it didn’t seem too bad at first.
Anyone been through this? What was your recovery like?
I broke the last rib on the left side of my back a couple years ago snowboarding. I got x-rays about a week after the accident and they were inconclusive becuase I went to some crappy old doc with crappy equipment, he had me lie on the table and I heard this is the worst way to x-ray ribs. I kept snowboarding every weeknend for the next month. Went back in for more x-rays and he could see a month later where the break had healed, when he initially saw nothing. I am fine years later, no issues.
Yes, been through bruised/cracked ribs a couple of times. General advice is that if it hurts, go and see a doctor or at least a chiropractor or physio. I found that they healed quickest if I did little to nothing for a week or 2 - exercising and hence having to breathe deeply puts additional stress on the ribcage. Gritting your teeth and training through it may be fine but may cause more problems - suggest you get a medical opinion rather than take the risk.
I fractured 3 ribs last summer (July 14). I needed help to sit up for 2 weeks, and it was about a month before the intense pain started to subside (as in scream in pain when you sneeze or laugh or God forbid your 2 year old jumps on it). It was 2 months before I could swim/run again.
There isn’t much they can do if the ribs are fractured or bruised.
Mine still hurt a little 6 months later.
yup. that sounds like bruised ribs to me.
i’ve had them 3 time now. after the first one, both times it happened i knew they were bruised, even though it took a while for the pain to set in. if you put pressure on your rib cage - by, say, sleeping on your back, or sleeping on your stomach, or sleeping on your side - you’re going to make thigns worse. So for a couple weeks it seems to get worse, and then after that it starts to get better.
Last time it happened, i talked to a friend of mine who is a doctor (although not a rib specialist at all). he said that i was, to some extent, at greater risk for breaking a rib (i was doing karate at the time). this isn’t really a swimming or running issue, it is a potential bike issue, but i don’t know if it makes a difference really. he also says that if you do a lot of hard effort, deep breathing stuff while the rib heals, it will hurt & slow the recovery, but the rib will be more elastic/flexible because of that.
but bruised ribs are a bitch, no 2 ways about it.
the only thing i’ve found that helps is taking a claritin a day, just in case. if you have sneezed today, you should understand why.
best of luck in your recovery.
-charles
As others have said, not much you can do to treat them but rest. I broke my 3rd and 4th left posterior ribs in September and it was pretty uncomfortable for a few weeks afterwards, it always felt like I had just been punched hard in the back. It was about a good two months before they felt normal.
Can you say rib fracture? If it hurts to run, etc, it’s probably fractured. A lot of ‘bruised ribs’ are simply fractures that don’t show up on xray. One often only sees heeling bone 2 weeks later. It doesn’t effect the outcome.
It probably wasn’t the equipment. See above.
Had two of those. The pain is increasing the first days, worst between day 5 and 8, then slowly better. Might take more than a month to get completly rid of all pain.
The doc’s can’t do anything, and you can not do anything to get it grow faster or slower (except if you have a new crash). Do whatever you want to do. I had a top result in sprint-tri a few days after + a decent 1/2 marathon a week after the tri.
It did hurt like h… , but I recovered within a few weeks.
(After the first one I was really careful, didn’t run for a month. Had a much longer recovery.)
Going through the same thing myself. Separated or bruised right side floating rib a couple weekends ago. Running is a definite no for me right now. Tried on tuesday night and felt I set myself back a week. I’ve got a wicked case of apathy going right now, so skipping workouts isn’t too tough for me. I’ve been told 3 to 4 weeks.
Since this is rib injury number 3 for me, I knew I should take the time to heal before getting back into things. But, as a triathlete-train-too-much-hot-head, I waited a full day before getting back into things.
I hear you with the apathy. I think it may be the restless nights and constant pain that seem to accompany crashes but I tend to lose interest in pretty much everything and go into a funk in the week following a crash too. Usually passes pretty quickly though.
I had something similar… went to the chiropractor and he suspected that I had pulled the ribs out of my back (somewhat). Mine didn’t seem bad but 4 days later I was in pain and couldn’t do much.
I went through 1-2 times weekly chiropractic, then every other week, for a couple of months. Then I had massage to help loosen the muscles so they wouldn’t pull on the bones, so the bones could heal back into place.
It took about 2 months to feel right again. I couldn’t train and I couldn’t walk well – if you can train then perhaps it’s not too bad…? (IMHO). Go get a professional opinion so you know for real.
Lauren
