I am totally addicted to training by power, and plan on racing with my power meter. Right now that’s a Powertap pro. Here’s where it gets interesting…
My PT wheels are relatively rugged: 24h sapim CX-ray front w/ Campy hub, DT rims, rear is same, but 28h, and PT hub. Nice wheels. But we all know they aren’t sexy enough. I mean come on, how can you show up early to the transition area with those? It goes without saying that a novice needs better.
I had been thinking I would build a set of Z404s, either tubs or clinchers (another debate). Seeing the price hike, I started thinking Heds (Jet60s, etc).
And then I realized that I’m going to want to be able to ride on my stationary trainer, on both the road bike and TT bike. No way should those race wheels be on a trainer (whether they “could” or not is an unrelated issue). That means swapping wheels all the time, as does riding the TT bike on the road unless I’m going to roll around on carbon (and possibly tubulars – double undue expense risk).
Now mix in that I have a perfect set of Rolf Vigor Primas sitting lonely in the garage since you can’t stuff a PT hub in there. That got me thinkin’… if I had an SRM, this would all be fixed – I’d race on the Rolfs. Of course, the downside is I’d have an SRM on one bike, and a PT on the other, and spend almost as much on the SRM as a PT/Z404 combo which would be a better wheel.
Hmm. 1) Build a PT-hubbed set of nice race wheels, swap training wheels around to whichever bike I train on that day. 2) Put an SRM on the aero bike, train on another set of Campy wheels I have, race on the Rolfs. 3) Skip it all and just swim.
Clearly you need a set of Zipp’s built around a power tap, so you end up with your current Powertap wheels for training, and your Zipp Powertap wheels for racing.
Regarding this exact topic, we’ve been working with PT since last year on integrating their new hub into our lineup, and you can now get a PT SL in any of our built wheels (except the disc) straight from the factory, with our without the head unit. My choice would be the 808 or 606 with PT as the rear wheel is almost as fast as a disc from 0-15 degrees of yaw (about 60% of real world wind) pair of wheels will come in under 1500 grams even with the PT, and would be at or under the cost of an SRM.
Our website is still way under construction, but here is a rough idea of what’s going on:
Just put the PT hub into a Zipp404 clincher (it’s 24 hole like your hub).
Then use that rear wheel for everything & get a nice race specific front.
If you are doing a race that is so important that you are worried about the PT hub weight then use a disc for your A race.
Whoa – train on a Z404? And use it on a stationary? Yikes!
http://www.zipp.com/wheelfinder/powertap.shtml
Yep, that would be cool. You musta missed my comments on the Z404 price hike thread, though Any of you wheel dealers want to throw down a quote on that wheel? Campy-compatible hub. And does it have to be the SL version? I’m not worried about the extra weight.
JohnA, I am not sure about 420 rim availability, I know that they are being made, but it is an unbelievably difficult rim to make and takes a good bit longer per rim than anything else currently in production. Last I knew, we were taking orders at a rate higher than we could actually make the rims so my best guess would be early February if you ordered now.
If you want Campy-compatible the new SL is definitely the way to go instead of the powertap-pro. I know the pricing on the 606 and 808 is toeing the line for a lot of people, but if you can, at least consider checking one out in person, just for kicks even. The guy I just bought a powertap from has a prototype and it’s pretty unbelievable. It feels like a toy when handling it. Honestly, I was thinking to myself “You can ride on this thing?” Very deep section, extremely light, and you can tee it up if you run out of golf balls before you get to the 18th hole.
Major props to Rich Sawiris at www.wheelbuilder.com , he will talk wheels with you until you are sick of talking about them.
Nice mylar job, but I was thinking how funny it would be, in a perverse sort of way, to use that design with the “Crash Dummy” design (like the socks).
Swapping SRMs from bike to bike is much easier than people think - a lot of our athletes do it. Just get wiring harnesses for each bike, and it only takes one allen key to move the driveside crank from one bike to the other. No wheel compatibility issues, etc.
Makes sense. One thing that’s spooked me about the SRM is the maintenance – I’ve heard some say that it’s a pain to keep calibrated, etc. I also just spotted something in the manual for it… they suggest replacing it yearly!
Calibration isn’t that bad. You definitely need to do it when you first get it. I have yet to hear of anyone who found the factory calilbration to be correct.
They suggest replacing the crankarms, not the whole unit, once a year. This is directed at pro racers who ride 500 or 600 miles a week, not poseurs like us, anyhow.
Maintenance is a non-issue. Jens is right about needing to calibrate it when you get it if you want to be sure it’s accurate, but after that there are no issues. I’ve had my unit for 3 1/2 years and never had to do a thing to it, despite many long rides in the rain, swapping it from my road to tt bike, etc.
