Training benchmarks in the IM swim
What do you 1:00 hr studs and studettes do as benchmarks in training to indicate readiness? Lets assume IM swim is a wetsuit swim. TY.
1 hour straight swim (no wetsuit) in a 50 meter pool. Usually i get 3700+ meters at steady effort … that lets me know i’m right there (or 4100+ in yards) … depending on how rested i am doing i can finish this not feeling shelled. At race time after resting a bit, with a wetsuit for a little added speed, i have been 57:30 to :59 on all IM wetsuit swims.
Another one i used in a yard pool was 8x500 on 7:45 (2nd four faster than the 1st four … fources you to be patient he first half of the swim knowing you have to go faster in the 2nd half)
Good luck …
I can’t tell you how to become a fast swimmer, BUT, there is absolutely no reason, whatsoever, to swim for an hour straight.
After training for a few months, you should know whether you can hold 1:30’s (LCM) for a long set (with little rest in between swims). If you know that you can do that, you should be in the 1 hour range. You don’t need to bore yourself silly swimming 4000 meters straight.
Now, how you get to 1:30’s is a different story. 8x500’s is a solid set. 10x200’s. It’s hard to say what someone needs without seeing them swim. Everyone falls into one of 3 categories of need (1) technique, (2) aerobic, (3) both. No matter how fast you are, you can always use drill work. Everyone should drill in every workout. Ask Vendt, Thorpe, Phelps, whoever.
Following that line of thinking then, at what point should you not worry about your non-stop distance? Say for instance I have only swam 2000 meters straight, should I not occasionally go for the 4000 meter swim to make sure I have the capability?
If you have a goal of 1 hour, you should be able to do a set like 8x500’s, with 20-30 seconds rest between each one at 6:45 (scy) or 7:30 (LCM). You should be able to do a shorter set, like 10x200 at a slightly faster pace like 2:30-2:35 (scy) with 10-15 seconds rest.
Swimming in a pool for an hour without stopping does not give a good idea of whether you can swim in the ocean or a lake for 2.4 miles. There is no substitute for open water racing. But, if you can hold your “race pace” in long sets consistently, then you should be primed for a good race.
I found these thoughts from Gordo on the subject to be timely and insightful:
http://www.coachgordo.com/forum2/upload/index.php?showtopic=2356
For what it’s worth, my better half is a 50 min IM swimmer. She says, there is nothing to tell you that you can swim the distance at that pace, you just know it and if you don’t you probably can’t.
"there is absolutely no reason, whatsoever, to swim for an hour straight. "
I found this statement very interesting, can you please elaborate…?
My training benchmark was pretty straight forward - swim 2.4 miles in under 60:00 minutes and it not kill me! Then I knew that I could do it in an IM race.
Fleck
The only reason I have ever heard to swim an hour straight is to “see if I can swim XX distance at XX time.”
It is unnecessary. You can do a 3-4000 set. With short rest. At race pace. And not be too exhausted at the end of it. And not be nearly as bored. And you can do another set after it (if you felt like putting in the extra yardage).
Typical 1-hr ironman-er is a strong swimmer, but not great. You have been swimming for long enough to know your body. You know how fast you can swim.
Doing an hour swim at race pace, is very tiring, both mentally and physically. It also almost guarantees that you will do nothing else that day (at least in the water). Your technique will generally diminish over the course of that swim.
The only reason I can think of to swim that long, is that you are very mentally strong, and you just feel like doing a long swim, fairly easy. Good aerobic workout. Fine. But, as an indicator of whether or not you are a 1-hr 2.4 mile open water swimmer, unnecessary.
Also, just because you can swim 4100 yards in the pool in 56 minutes doesn’t guarantee anything in open water. Conditions, getting kicked in the face, swallowing water. Everyone knows, anything can, and has happened.
My main point is that an hour straight in the pool is a testament to your mental strength, not your race-readiness.
I can see your points and agree with some of them, but I woldn’t say there is not reason to do it.
Also the difference between a 8x500 or a 4000 straigth swim at the same pace is close to none.
Remember the original question was pointed at gathering ideas for what sub 1hr swimmers use to test readiness to swim that time during an IM. Nobody (or I) said it was necessary to do 4k straight BUT Chappy did ask what some of us use for benchmarks. I also use other benchmarks like 20x100’s on tight interval after along warm set including some fast 50’s. I agree that i can also “feel” when i’m ready to swim under an hour just by the training build up w/ a variety of endurance based swims and don’t need to do an hour straight.
*“My main point is that an hour straight in the pool is a testament to your mental strength, not your race-readiness.” *
Mental strength has everything to do with race readiness. (and it can be tested in other ways … like 8x500 etc.)
*“If you have a goal of 1 hour, you should be able to do a set like 8x500’s, with 20-30 seconds rest between each one at 6:45 (scy)” *
I have never been able to do that … i swam them in 7:30(1st 4) - 7:15 (2nd 4) on 7:45 … i have never swum over an hour for IM wetsuit swim and under 1:04 for non-wetsuit. None of them with alot of stress either.
Goes to show, as it should, that every athlete is unique and different. Again, Chappy was just asking what some of us use for benchmarks … not what guarantee’s a sub 1hr swim.
Okay, mental strength is a part of being race-ready, there is a huge difference between the mental strength it takes to swim by yourself in your own lane for an hour without stopping and the mental strength it takes to finish an ironman swim. In the pool, you just have to blank out and focus on something like technique, speed, etc. In the open water, you can’t just think about yourself, you have to be constantly watching. But, back to the subject (not really),
It’s hard for me to believe that you can’t go faster than 7:15 in a short course yards pool on a set like that, but you can hold 1:20’s or so for 4100 yards in a race, even with a wetsuit. Either (1) you loaf your workouts (2) you are a hell of a racer or (3) you have horrible turns that cause you to lose 5 seconds at each wall. In any of the above situations, all it does is prove that no two people’s benchmarks for race-readiness are the same.
In any case, my main point was that, to be a one-hour swimmer, you DO NOT have to swim for an hour straight at any point in your entire life, except for the actual race.
Also coach, yes 8x500 is boring, and I wouldn’t do that set too often, BUT, I would much rather be able to take 7 - 30 sec breaks during an hour, to fix my goggles, look at the lifeguards, talk to someone, whatever, than swim straight for an hour. You get as much benefit with 100% less boredom.
I agree, although I am no swim expert and never considered myself a good swimmer( 57:30 IM best).
Perhaps, I never really understood swimming. A staple of my spring/summer swims was the 4K straight swim in a pool or one hour in open water. To me it seemed to make sense. I did the same for running and cycling. It was essentially a 60 minute ITT in the water and I knew that the best training that I would/could do for a 10 mile running road race or a 40K ITT on the bike was long sessions at the goal race pace for those two events.
But then again I never really understood swimming!
Fleck
Don’t worry, I never understood swimming as well :wink: As a result, my athletes actually prefer to do a 2000m straigth swim than a 20x100m or 10x200 :-))
Check out this thread over on Gordo’s site:
I think when you read what these guys think, you really have to consider the long swim. This group of athletes are really doing what it takes to be extremely competitive IM athletes and I personally put a lot of weight on the points that they make. I really like opposing viewpoints (like yours) to remind myself that everyone is different and has their own thoughts about what they think works best. Anyway, check it out and maybe we can discuss the merits of their appoach?
“That would give a 57’30’'…ok no rest and no flip turns, but it’s easily compensated by the wetsuit and the big draft”
Those two things are huge. Near the one hour mark a good wetsuit and a great draft is worth 2 - 3 estimates from my experience. I would routinely swim close to people in an IM race most of the way that were trouncing me in pool work outs!
Fleck
I read gordo’s post and the first thing on my mind was “Goddamn, gordo just invented long continuous swims, why didn’t I thought of that!”…
I think we are on the right page … not so much that i can’t go faster than 7:15, more that i’m picking an effort that is VERY doable so i can train later in the dy or get up the next moring and keep plugging away at the process. BUT i typically race bettre than i train and my flip turns are average. I do agree that it is not necessary to swim an hour straight but when i do it’s likely for the brain :wink:
Good discussion …
Sarcasm I guess? Not that he “invented” anything, but that many of the posters give good insight about what they feel about long swims as a necessary part of their training. That is where this thread is heading. If one wants a “benchmark” of where they are at for a long swim (like IM) then it seems to me that one has to do a pretty long swim. If it is in a pool, then that is the best some can do. Better if it is in open water and better yet if you are wearing a wetsuit and there are people swimming around you.
